Thread: Powerlog leak
Results 1 to 5 of 5
  1. #1 Powerlog leak
    Sep 2011
    South Central PA
    How did you guys with powerlogs get it to seal at the crossover? My stock manifold didnt have a gasket and I even checked in the parts dept at work to make sure it didnt come with a gasket from stock. From factory the manifold does not have a gasket there. My powerlog leaks like crazy. I used high temp rtv but its too flexable and blows out when I boost. So how did you guys do it?
    2000 Grand Prix GTP Daytona 500
    WBS PCM, 3.5 Pulley, 3'' DP into Magnaflow Hi Flow Cat, Powerlog, No resonator, Wizaraid Intake, ZZP Wires, AL 104's, 180 Stat, Poly Dogbone Bushings, Optima Yellow top battery
  2. #2 Re: Powerlog leak
    HUDSON
    Try loosening both crossover pipe connections at the manifolds/powerlog first, wiggle crossoverpipe around till it fits good at both ends, retighten bolts. Tighten boths end gradaully, a little at one end, then a little at the other end, repeat.
    This is how I installed mine, it seal fine with no RTV.
  3. #3 Re: Powerlog leak
    Texas
    Check the parts store. You are looking for the exhaust crossover gasket. Mine is leaking as well. I need to go back and install the gasket.
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: Powerlog leak
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Quote Originally Posted by txslow6 View Post
    I bought a seal like this felpro I think... I think I got the rear portion of the crossover seal tho. MAybe who knows
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  5. #5 Re: Powerlog leak
    Florida
    same here as well. everytime on cold starts its like a chattering noise cuz no tight seal but it goes away when its warmed up.
  1. HV3 or powerlog
    By OmegaRed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2011, 07:13 PM
  2. Powerlog
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2009, 02:06 AM
  3. Powerlog and 10.4mm PRJ's
    By whitelightnin04MC in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2008, 01:10 PM
