Thread: Fuel Gauge Issue
Results 1 to 11 of 11
  1. #1 Fuel Gauge Issue
    SE Level Member Lawenforcer's Avatar
    Shelbyville, IL
    Hello,
    On my 2000 GTP that I just got, I am having an issue with the fuel gauge. When I fill the fuel up it will only go up to about half way between 3/4 tank a full. I have just been running off what my "Range" says so far, but want to fix it. I just cant handle not having everything working properly. If anyone has had this happen or suggestions on what to check or try then please let me know. I appreciate all the help. Thanks
    2000 Grand Prix GTP
  2. #2 Re: Fuel Gauge Issue
    Fuel level sensor/sender.
    Youtube "bonneville fuel level sensor" there is a guy that does a 3 part video on how to replace it, I've done it, its pretty simple.
  3. #3 Re: Fuel Gauge Issue
    Never Never Land
    FFDP pretty much covered it. Do you enforce the law?
  4. #4 Re: Fuel Gauge Issue
    Shelbyville, IL
    I will check it out, hope it isn't to difficult. Thanks Again
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    No, I just pretend like I do, I play cop during the day, lol!!!
    2000 Grand Prix GTP
  5. #5 Re: Fuel Gauge Issue
    Omaha, NE
    It's probably a bad fuel level sensor.
    ACDELCO Part # SK1091
    $131.79 on rockauto.com
    But I question that due to you saying the range is correct.
    Due to that I think it could be a mechanical issue with the gauge itself.
  6. #6 Re: Fuel Gauge Issue
    Shelbyville, IL
    Now, you got me wondering. I hate to do all the work/price replacing fuel sender unit and not fix it. Decisions, Decisions. I am not sure what route to go. I do have aftermarket face on my gauges. I wonder if it could be messing it up. The gauge doesn't fluctuate or anything. It just doesn't go past the half way mark between 3/4 and full. Not sure what to try first.....
    2000 Grand Prix GTP
  7. #7 Re: Fuel Gauge Issue
    Omaha, NE
    I would check free things first. There's no point in spending money when you don't have to.
    Did the problem happen before the new gauge face? It could be raised, or improperly seated preventing the needle from moving.
    Besides that some other free things to check would be the mechanism. If you take the clear plastic face off, see if the needle has too much or not enough tension. Use your best judgement on what is tight or loose there.
    Make sure the wires and plugs are in and seated the best they can be, and there is nothing on any tips keeping them from making a strong connection.
  8. #8 Re: Fuel Gauge Issue
    Shelbyville, IL
    I will try to figure out how to check the gauge first. I don't know if it was doing it before the gauge face. The face was already done when I bought the car and unfortunately it's been acting up since I bought the car a couple weeks ago. It's just driving me nuts not having it work correctly, lol....I appreciate the advice.
    2000 Grand Prix GTP
  9. #9 Re: Fuel Gauge Issue
    Lol wut 131!!!!!!!!!!!!!!!!!????????????????????????//
    That not even close to what you should be paying for that part.
    New Fuel Level Sensor (Sending Unit) | eBay
    Follow the video on youtube and just switch out the parts like he does.
    I bought that very same part off ebay over a year ago, works perfect.
  10. #10 Re: Fuel Gauge Issue
    Shelbyville, IL
    That price is so much better. Think I will be ordering it Monday. I will try to put it on my next days off. Might need a few of those beers he had in that video,lol....
    2000 Grand Prix GTP
  11. #11 Re: Fuel Gauge Issue
    I know in the video he hammers the ring off from around the pump to get it off, but on GP's its just a snap ring.
    ANd it helps to have 2 people to get the pump back in sometimes, one to hold it and the oter to push it down to get the snap ring in place again. I used a rubber mallet and very carefully tapped it down to get it so seat.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Help With Temperature Gauge issue!
    By gcschi22 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2011, 10:55 AM
  3. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  4. Rpm Gauge issue
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-27-2011, 10:20 AM
  5. boost gauge issue vid
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2009, 09:44 PM
