Thread: gtp sluggishn
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: gtp sluggishn
    Omaha, NE
    If we are talking to someone who is new to the platform, I would not advise it. A box tune won't SAFELY work for a 3.4 on a gen v without a cam, rockers, intercooler or E-85.
    If it were someone who had good tuning experiance with the platform and was willing to take the time to tune and scan, yes it is "possible" to safely run a 3.4 given injectors aren't being maxed, and other supporting mods are in place.
    No offense to anyone, but this situation seems to fall in the first category.
  2. #22 Re: gtp sluggishn
    TENNESSEE
    ok so whats with the different size lower intake inlet?
  3. #23 Re: gtp sluggishn
    Omaha, NE
    Top left is a Gen V Lower intake Manifold................Top Right is a Gen 3 Lower Intake Manifold
    They won't look EXACTLY like stock since they have ZZPs standard port, but they are similar.
  4. #24 Re: gtp sluggishn
    TENNESSEE
    the 04 looks like the one on the left of corse but the 05 is half that size i had to take it to a machine shop to get cut out to that size
  5. #25 Re: gtp sluggishn
    Omaha, NE
    So was it more like this?
    I'm just trying to make sure we are looking at the same stuff here.
  6. #26 Re: gtp sluggishn
    TENNESSEE
    yes exactly
  7. #27 Re: gtp sluggishn
    Omaha, NE
    That is a Series II Lower Intake Manifold made for the Gen 3 blower.
    Here is a pic of a non-ported Gen V Lower Intake Manifold from a Series III (with a gasket sitting next to it)
    If you still have your factory Lower Intake Manifold that was on the 04 GTP when you got it, I would reccomend putting that on. It should help the motor flow a little better and hopefully reduce some of that KR.
    Also, this makes me question if the motor you got is from an 05 since the Gen 3 was not used in Grand Prixs after 2003.
    What color are your valve covers, Black or Tan?
  8. #28 Re: gtp sluggishn
    TENNESSEE
    their tan
  9. #29 Re: gtp sluggishn
    Omaha, NE
    As far as I know all 04+ Supercharged Grand Prixs came with Black. I know that Naturally Aspirated 04+ Grand Prixs and 97-03 Supercharged Grand Prixs had tan.
    The good thing is that you have Supercharged heads, or the Lower Intake Manifold and Fuel Rail wouldn't work.The downside of that is that we don't know if those heads were the heads that came factory with the block. If it IS an 05 block and someone topswapped it with a gen 3 then sold it as a GTP motor, the compression difference between the Naturally Aspirated block you would have and the Supercharged block your PCM would think you have could be potentially dangerous.
  10. #30 Re: gtp sluggishn
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Im on a Gen 3 but still have a 3.6 even tho after my scan know I could rock a 3.5 or maybe 3.4.... Why because you have to pet it like a little horse realllllyyyyy tiny horse.
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  11. #31 Re: gtp sluggishn
    Omaha, NE
    Quote Originally Posted by chevyy1212 View Post
    Pic related?
  12. #32 Re: gtp sluggishn
    GT Level Member NR92's Avatar
    Atkins, Ia
    My 04 gtp motor had tan valve covers, if that changes anything
    2004 GTP Comp G -- Sold
    2006 GTO Magnuson supercharged
    2007 Ram 2500 QCSB 4x4 5.9 Cummins, Efi live, Exhaust, Intake N'stuff
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    Quote Originally Posted by NR92 View Post
    My 2004 gtp also has tan valve covers.
  14. #34 Re: gtp sluggishn
    I live here. TLSheff's Avatar
    My 99 had tan valve covers but I painted them silver...
  15. #35 Re: gtp sluggishn
    Kansas
    My '05 NA came black.
    I call bull****.
  16. #36 Re: gtp sluggishn
    Copgtp told me that he saw a 3.4 on a gen5 without headers without knock so it may be possible i guess with tuning.
  17. #37 Re: gtp sluggishn
    Minnesota
    Anyone with the mods OP is planning should have a custom tune or buy a tuner.
    Can tune isn't going to cut it.
  18. #38 Re: gtp sluggishn
    Possible but not likely.
    But because its possible, you can try it and scan. But start with a larger pulley and scan.
    Add timing and see how much you can add.
    If you hit 20, try a smaller pulley.
  19. #39 Re: gtp sluggishn
    Oct 2008
    IL
    Pic related?
    I think those are still big when you look at them next to the tree. The Pink and purple is all you lol
  20. #40 Re: gtp sluggishn
    SE Level Member jrock's Avatar
    Jun 2010
    southpittsburg tn
    Ok fixed the lean problem. Egr was stuck open. Bought a new one running great. Now gotta take care of that knock!!
