Thread: Sunroof lube/grease?
Results 1 to 3 of 3
  1. #1 Sunroof lube/grease?
    SE Level Member 7point62's Avatar
    Sep 2011
    Canada
    Opened the sunroof on my '01 GP for the first time in several months yesterday. Seems very slow to open now and the motor sounded like it was working pretty hard. I think my rubber may be dried out (though it isn't cracked) and I think the tracks need some new lubrication. There's hardly any grease and what is there is pretty old and gummy.
    What kind of lube or grease do I use for the sunroof tracks and is there anything I can put on the rubber? Brand new seals are pretty damn expensive.
  2. #2 Re: Sunroof lube/grease?
    rubber gets silicone.
    tracks get white lithium grease.
    Should be in the owners manual.
  3. #3 Re: Sunroof lube/grease?
    Sep 2011
    Canada
    Thanks, I did check the manual actually but it only mentions lithium for the door hinges, I wasn't sure if it would be the same everywhere but that makes sense.
  1. ARP lube for rocker install. What for?
    By Rust in forum General Tech Discussion
    Last Post: 12-18-2011, 10:04 AM
  2. trans lube tube updates anyone?
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-25-2011, 03:09 PM
  3. Silicon lube window rails?
    By tdm571 in forum General Tech Discussion
    Last Post: 06-01-2011, 08:42 PM
  4. Where do I get S/C grease?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2009, 11:58 PM
  5. grease???
    Last Post: 10-20-2009, 02:31 PM
