On what fuel?
.065 4 layer would suffice. The problem is that a stock gasket would probably hold on 15psi depending on the afr/fuel type/timing. Saying flat out that you're never going over 15psi on a t67 on such fuel and such timing you would probably want to go with a shorter thickness.
