Thread: gtp shutting of while driving
Results 1 to 10 of 10
  1. #1 gtp shutting of while driving
    Jul 2010
    bahamas
    Ok Help I have a 2000 gtp and while driving at times it shut down on me, it would take a few seconds to start. I change the fuel pump and mass air flow sensor and the car still shut down, What can I do.
  2. #2 Re: gtp shutting of while driving
    do the rpms just drop to zero on the dash then the car shuts off soon after???
  3. #3 Re: gtp shutting of while driving
    St. Louis
    Sounds like maybe another flaky CPS. Do you have a CEL on?
  4. #4 Re: gtp shutting of while driving
    Jul 2010
    bahamas
    yes the rpm drops to zero,and my abs,tcs lights are also on.
  5. #5 Re: gtp shutting of while driving
    Quote Originally Posted by FordMan77 View Post
    Sounds like maybe another flaky CKPS. Do you have a CEL on?
    CranKshaft Positiion Sensor. And I agree on the diag.
  6. #6 Re: gtp shutting of while driving
    St. Louis
    Well, if you want to be all techni, tekni, well you know then yes it IS a crankshaft position sensor. I stand corrected
    Whatever its called I have to put one in the Bonne now, dang it! I better not stick the balancer back on like Bedwards or I'm screwed.
  7. #7 Re: gtp shutting of while driving
    Only reason I got technical is because if they go in for a cps, they'll get a camshaft position sensor.
  8. #8 Re: gtp shutting of while driving
    Jul 2010
    bahamas
    just a belated thank you all for your answers... It was the cps
  9. #9 Re: gtp shutting of while driving
    It was the Cam Position Sensor, CPS? Or the CranK Postiion Sensor, CKPS? Usually it's the cranky postiion sensor. Yes..I've asked that the name include the "y" as they do get cranky...lol
  1. Car shutting off.
    By 98GTP PaceCar in forum General Tech Discussion
    Last Post: 10-11-2010, 11:59 PM
  2. 2000 Pontiac Grand Prix Shutting off while driving
    By Spudy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-22-2010, 05:00 PM
  3. car shutting off while driving
    By cwgtp98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2010, 05:33 PM
  4. Car just shutting down....
    By AZGXP in forum 5.3L V8 (LS4)
    Last Post: 09-11-2009, 01:18 AM
  5. GTP Shutting off
    By ryan88z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2008, 08:42 PM
