Thread: MLS Head Gasket Difference
Results 1 to 6 of 6
  1. #1 MLS Head Gasket Difference
    GT Level Member ls1camino's Avatar
    Laurel, MD
    A friend is building a new motor and we're trying to figure out the pricing on ZZP's MLS Gaskets...
    .045" = $155...3-layer
    .051" = $155...3-layer
    .052" = $165...4-layer
    .060" = $175...5-layer?
    .065" = $165...4-layer
    .066" = $185...6-layer?
    .074" = $175...5-layer?
    Also, for a T67 turbo application pushing about 15psi on a L67 bottom end, what thickness would you recommend?
    Any help would be appreciated, thanks.
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: MLS Head Gasket Difference
    no 3 layer.
    4 layer would be fine.
  3. #3 Re: MLS Head Gasket Difference
    Jan 1970
    Maquoketa, Iowa
    On what fuel?
    .065 4 layer would suffice. The problem is that a stock gasket would probably hold on 15psi depending on the afr/fuel type/timing. Saying flat out that you're never going over 15psi on a t67 on such fuel and such timing you would probably want to go with a shorter thickness.
  4. #4 Re: MLS Head Gasket Difference
    Laurel, MD
    93 pump gas.
    I said "about" 15psi, lol. Im sure Ill go higher.
    Zoomer said .060" would be best.
  5. #5 Re: MLS Head Gasket Difference
  6. #6 Re: MLS Head Gasket Difference
    Laurel, MD
    Copper spray is my friend.
  1. cracked head blown head gasket or just done??
    By roytoy70 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 10:40 PM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. Head Gasket ?
    By suntoy68 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2011, 04:01 AM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
