Thread: Should I replace the Radiator Cooling hoses?
Results 1 to 11 of 11
  1. #1 Should I replace the Radiator Cooling hoses?
    GT Level Member andremike's Avatar
    Nov 2009
    chicago
    How often should these hoses be replaced? I was thinking about replacing them.. Do I replace them all?
    How many are there? I seem to have found 4...
    LOWER HOSE:
    ACDELCO Part # 26354X {#88909051} 1 9/32" x 1 17/32" x 16 5/16"
    HOSE,MOLDED 2 DOORS; LWR
    HOSE,MOLDED 4 DOORS; LWR
    UPPER HOSE:
    ACDELCO Part # 26346X {#88909043} 1 1/4" x 21 3/16"
    HOSE,MOLDED 2 DOORS; UPR
    HOSE,MOLDED 4 DOORS; UPR
    Then what are these hoses?
    ACDELCO Part # 18287L {#88920912} 19/32" x 24 29/32"
    HOSE,MOLDED 4 DOORS; HTR TO ENG, UPR
    HOSE,MOLDED 2 DOORS; HTR TO ENG, UPR
    ACDELCO Part # 18251L {#88920876} 5/8" x 23/32" x 22 19/32"
    HOSE,MOLDED 4 DOORS; HTR TO ENG, LWR
    HOSE,MOLDED 2 DOORS; HTR TO ENG, LWR
  2. #2 Re: Should I replace the Radiator Cooling hoses?
    I did them on my last two DD's. Figure 150K-200K miles ...everything has a little wear and tear.
  3. #3 Re: Should I replace the Radiator Cooling hoses?
    Nov 2009
    chicago
    oh! My car has only 73K, but its 12 years old. So technically it shouuld have that kind of mileage. I would think with rubber hoses its more of a age thing, than mileage..
  4. #4 Re: Should I replace the Radiator Cooling hoses?
    Take a look at them. Do the corners of the hoses feel soft etc? That's how you tell you need them
  5. #5 Re: Should I replace the Radiator Cooling hoses?
    Nov 2009
    chicago
    I don't know I felt the hoses.... they feel like hoses.. are those 4 hoses the right part number? Should I do all 4 hoses? Do you need to take out the headlight for the top hose?
  6. #6 Re: Should I replace the Radiator Cooling hoses?
    Nov 2009
    chicago
    I caled to get a price on replacing the up and low radiator hoses and my mechani wants $150.00. That seems awfully high for 2 hoses.. he said its .7 hours per hose. The other 2 hoses to the heater core they will not change because they say the hoses seize to the core... and when you replace it it will leak...
    Does any of this make sense?
  7. #7 Re: Should I replace the Radiator Cooling hoses?
    St. Louis
    First off is this something you can do yourself? And as far as changing the heater core hoses thats BS. All you have to do is remove the clamp, grab the hose and give it a twist to break it free from the heater core line. Then just twist and pull back at the same time and viola! you have removed the hose. Obviously you don't want to hulk up on it as the core is thin metal and "could" break a seam, but if you are carefull you should have no issues. Done this for years and have yet to cause a leak.
    And that .7 hours is book time. You will get billed that regardless of the 30-45 min. it takes to change those 4 hoses. The longest part will be refilling the system w/ coolant and bleeding all the air out of it. That I could see taking a good solid hour.
  8. #8 Re: Should I replace the Radiator Cooling hoses?
    Nov 2009
    chicago
    Thanks for the info... I don't think I will do the heater core hoses.. ill have to return them.. I saw the utube video on the other ones.. I think ill just pay someone... hopefully I really needed them... but the car is 12 years old
  9. #9 Re: Should I replace the Radiator Cooling hoses?
    SE Level Member midrange's Avatar
    Belleville, Ontario
    I guess i'm old school.. I don't replace unless I have too. And by that, i mean when they start leaking.
    2004 Grand Prix GT1
    When they get soft or hard then its time for replacement.
  11. #11 Re: Should I replace the Radiator Cooling hoses?
    Antioch, IL
    I want blue radiator hoses. But refuse because to do the passenger side SUUUUUCCCCKKKKKKKKSSSSS.
    2009 Challenger SRT8
    Expert at being gay.
  1. What to replace radiator trans cooler lines with barbed fittings. Which to buy?
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2011, 11:10 AM
  2. Anyone Know About These Clear Cooling Hoses?
    By erichamby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2011, 06:40 PM
  3. Collapsing radiator hoses
    By b3gtp in forum General Tech Discussion
    Last Post: 04-03-2011, 05:59 PM
  4. Hoses VS Belts.
    By GTPRiley in forum The Rant Forum
    Last Post: 01-05-2009, 05:44 PM
  5. Clear hoses!
    By boosting98 in forum Off Topic Discussion
    Last Post: 09-29-2008, 08:43 PM
