Thread: Better way??
Results 1 to 13 of 13
  1. #1 Better way??
    TDCRacing
    Guest
    This has been a problem for some time now. Intercooler hoses rubbing on the belt constantly.Cant even zip tie them to anything becuase nothing is available.
    I guess i couldnt just flip the i/c core around so the inlet/outlet would be facing the drivers side instaed of the passenger side huh?
    And body have any thoughts on this??
  2. #2 Re: Better way??
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by TDCRacing View Post
    Nope, can't flip it around. I ran mine like that for a long time when I had my ZZP core and never really had a problem, but yeah it is a sh*tty place to run them.
    Doubt you could do it with the ZZP core but I've got mine run like this now. Maybe it'll be possible if you get some rubber elbows and put on the inlet and outlet.
  3. #3 Re: Better way??
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Yea man I was looking at that and I really dont know what you could do. Im no expert but..
    How about super glue? Duct tape?
    Super glue isnt a great idea...It will eat the plastic tubing... Neather is a hot glue gun.
    Duct tape those suckers down with some high quality tape! 3M?
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  4. #4 Re: Better way??
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    I routed the one on the front turned 90º and under the spark plug wires. The other I routed back away from the belt and over the fuse panel.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  5. #5 Re: Better way??
    Bartlett, IL
    Damn how much does an intercooler cost? And install? I looked at my S/C and those holes werent there... >:|
    How To: E-Brake Pwn
  6. #6 Re: Better way??
    Barksdale AFB, LA
    Definitely get some 90* elbows and route it away from the belting.
    2009 Subaru Impreza WRX STI
  7. #7 Re: Better way??
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    I'll put it on the list. The long list lol.
  8. #8 Re: Better way??
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    90's are the way to go but i doubt even the best duct tape would hold them with all the heat from the engine
  9. #9 Re: Better way??
    Apr 2008
    Chillin at the Beach , VA
    Quote Originally Posted by stlmo_gtp View Post
    JB Weld
  10. #10 Re: Better way??
    St. Louis
    jb weld is pretty strong but i have even had that crack before from exhaust heat never used it on an engine part before
  11. #11 Re: Better way??
    Apr 2008
    Used it on time on a friends tranny. He liked to off road in his car and riped the speedo cable out one night. Never had a problem with it leaking.
  12. #12 Re: Better way??
    St. Louis
    hmm maybe the jb weld does live up to it's name then, i must have had bought the bad one
  13. #13 Re: Better way??
    Moore, Oklahoma
    Yeah, defaintly don't run them between the belts, that a failure waiting to happen and many GPers over the years have had that very problem. One of the reasons why I didn't get a ZZP IC for my car, the hose routing. Instead I found a MAP IC core for dirt cheap, sent it to PRJ to be recored and a machine LIM. The results.....
    As you can see, the line enters above the crossover pipe, though the core, and exits out beside the alternator, to the fill T and back to the FMHE. Although this is an outdated picture now. I have a custom pressized IC res and the ugly catch can on the MSP is gone for something fancier. I'm in the middle of the make over currently. This setup works PERFECT for my car, its almost as if it was made for it which it pretty much was. There are only 5 or 6 of these units out there customized by PRJ last I heard anyway.
    On my other GTP, I ended up putting on an old ILGPC core (Ron Vogels old core actully). The exits on it were like the ZZPs, but I ended up putting on 90 degree AN fittings and running the hoses over the coil packs, above the battery into the fenderwell. Works pretty well for a budget IC setup. I wish I had pics of that setup. It uses a Cobalt SS filler T above the battery.
    Shawn W. Larsen
