Thread: P0440
Results 1 to 2 of 2
  1. #1 P0440
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I got this CEL code P0440. The light turned on right after I started my car, The car was still warm. The light was on for only a few minutes before turning back off.
    Scanned the car the next day, Got this code. Found out that the common problem for this code is the gas cap being lose. In this case mine was not. I just got back from kodiak, and my wife says the light came back on for a few minutes and turned off again, Scanned the car and got the same code.
    So what should I do/look for to cure this problem?
    Gas cap is fine/never had a problem with it.
    The code states: Evaporative Emission System. Which I do not know anything about so any suggestion would be awesome.
    Let me know if you need any more info.
    Thanks.
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
    Modesto, CA
    It is a leak in your EVAP system. Most of the time caused by a defective gas cap not holding pressure. Before you try replacing the gas cap (cheapest place to start), try cleaning the gas cap, throat and top of fuel filler tube.
  1. DTC Codes P0440 and P0452
    By Longshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2011, 01:44 PM
  2. dtc code p0440
    By churchryan55 in forum Introductions/Noob Questions
    Last Post: 01-23-2011, 12:23 PM
  3. p0440
    By eroth in forum Introductions/Noob Questions
    Last Post: 03-29-2009, 11:05 AM
  4. p0440
    By eroth in forum General Tech Discussion
    Last Post: 03-23-2009, 07:45 PM
  5. P0440 code
    By Z28 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2008, 04:32 PM
