Thread: '98 GT 3.8 won't crank
Results 1 to 20 of 24
  1. #1 '98 GT 3.8 won't crank
    Omaha
    Hi, my daughters 1998 GP GT won't turn over, this was after it started 5 minutes earlier before she stopped for gas. I don't believe it's the battery or connections as lights and horn work well. It doesn't even make a click at the starter. I tried in park and nuetral with no luck, we also tried jumper cables, no luck. Any ideas? Her car is at a convenient store and I don't think they want it there, lol. Thanks, Tom
  2. #2 Re: '98 GT 3.8 won't crank
    Jun 2011
    Detroit, MI
    Check the fuses under the hood, one might have blown.
    iLoveSpade
  3. #3 Re: '98 GT 3.8 won't crank
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    crank fuse in the under hood fuse bank.. good start in my opinion
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  4. #4 Re: '98 GT 3.8 won't crank
    does the motor turn over and try to start or does it just do nothing when you turn the key
    SMGPFC Member #10
  5. #5 Re: '98 GT 3.8 won't crank
    Dec 2011
    Grand Prairie, Tx
    short in your starter wires? Possibly a ground too, my buddy had a ground come loose from his car and his did the same thing
    Ohio
    There's nothing at all? Do the lights come on, dim then no starter noise?
  7. #7 Re: '98 GT 3.8 won't crank
    brunswick
    lol dam you hippo
  8. #8 Re: '98 GT 3.8 won't crank
    Omaha
    wont crank or turn over at all, starter does nothing. Headlights are strong as is the horn. I am not with the car so I can't easily check if headlights dim with turning the key. I will go check fuses, thanks!!
  9. #9 Re: '98 GT 3.8 won't crank
    starters dead or loose connection
    SMGPFC Member #10
  10. #10 Re: '98 GT 3.8 won't crank
    I'd say starter try banging on it with a hammer while turning the key
    Ohio
    It didn't run rough prior doing this did it? Ever have any major work done to the car?
  12. #12 Re: '98 GT 3.8 won't crank
    Omaha
    Nope, ran perfect until she stopped for gas, then no crank. weird
    Ohio
    Start checking fuses then
  14. #14 Re: '98 GT 3.8 won't crank
    Jun 2011
    Detroit, MI
    Maybe teh Hippo is right!
    Teh Hippo strikes again~
    iLoveSpade
    Ohio
    Maybe teh hippo needs to wait and see
  16. #16 Re: '98 GT 3.8 won't crank
    Jun 2011
    Detroit, MI
    It sounds exactly like a fuse issue. It couldn't really be anything else. I'm guessing the when she turned the car off to get gas, a fuse popped.
    iLoveSpade
  17. #17 Re: '98 GT 3.8 won't crank
    Dec 2011
    Montreal
    If it's not a fuse...
    If the bearing in the starter is gone, the rotor rubs against the stator and shorts out the starter. As dsmuts said, try to give it a shot while turning the key. If this is the case though, most of the time, with the lights on, they will dim as there is now a short in the system. As there is nothing when you turn the key, it sounds like a neutral safety switch or the ignition cylinder, most likely the neutral safety switch
    If the starter was bad, the starter selenoid would still click, so I doube there is any power getting to the starter selenoid. Double check and see if you are getting voltage on the purple wire of the starter when someone turns ignition to start. If you get voltage, your problem is the starter.
    Try this (found this on another site)...
    Here's basic step-by step instructions on how to adjust the neutrsl safety switch.
    The neutral safety switch is located On the transmission right near where it meets the engine. You will see the arm and shift cable right on top of it when you look below the master cylinder.
    -Start with the car off and set the parking brake
    -Place the car in Neutral
    -Find the PRNDL switch and loosen (dont remove) the two bolts holding it to the trans
    -Have an assistant jump in the car and attempt to start it
    -if no start have the assistant hold the key in the start position
    -you go grasp the PRNDL switch and adjust it one way or another untill the car starts
    -Tighten the bolts down
    -Attempt to start the car in both Park and Neutral, and verify your backup lights function
    -repeat process untill everything works, test drive.
    Ian
  18. #18 Re: '98 GT 3.8 won't crank
    On my mom and dads mountaineer the ground wire from the starter to the block broke in half and the lights wouldn't dim or anything just wouldn't start.
  19. #19 Re: '98 GT 3.8 won't crank
    SE Level Member midrange's Avatar
    Belleville, Ontario
    I had simular issue with another car.. it was wires going to starter..
    2004 Grand Prix GT1
  20. #20 Re: '98 GT 3.8 won't crank
    Omaha
    The verdict is in, bad starter.
  1. NO Crank
    By BillO in forum General Tech Discussion
    Last Post: 12-18-2011, 11:39 PM
  2. .
    By Leon in forum General Tech Discussion
    Last Post: 02-02-2011, 08:24 PM
  3. Crank key
    By Enzo354 in forum General Tech Discussion
    Last Post: 10-26-2010, 03:45 PM
  4. Car Won't Crank..Again
    By brandonl2000 in forum General Tech Discussion
    Last Post: 07-30-2010, 12:58 PM
