All you need to know is posted in the very first post. In addition to that, I was seeing 11-12psi on the 2.8 with the open down pipe. More like 15psi on the street through the stock catback. The temps/time and other weather info are in the picture I posted in response to pure2sin's ridiculousness, it was like 60 degrees. The e60 comes from the only gas station in Connecticut that sells "e85". Everyone said to test the fuel to verify ethanol content and when I did I was pretty disappointed. There's definitely a lot more to be had from some proper summer blend e85.
I posted the cost breakdown like 4 posts above, but here it is again so that everyone is clear.
This... You're not going to make more power on a turbo setup unless its well built with a good IC. That's gonna cost ya. DH will be in here in a minute to tell you he runs 30psi through the stock engine and makes 600whp, but in reality most turbo setups will see under 350whp.SLoW SHO
So far the budget isn't working out too bad...
TVS with 3 pulleys $1200
Adapter plate $300
M62 for mockup $80
Alt Relocation $60
Sold my GenV and pulleys/MPS for $700
So far this has cost me $940. I'm pretty confident that I wont need a whole lot more as there isn't much left to do.
Yeah he's willing to make more. We still have to verify whether or not the plate works with currently available IC cores.
