Thread: Light Smoke coming from engine comp, Infrequent
Results 1 to 3 of 3
  1. #1 Light Smoke coming from engine comp, Infrequent
    Edmonton, Alberta, Canada
    About a month ago replaced my Engine Coolant Temperature sensor and Thermostat in 2000 GTP. The operating temp of the thermostat installed is (90C/194F) however the temp gauge in the vehicle often reaches upto (105C/221F) before dropping down to (85C/185F) then builds back upto (90C). The temp gauge does a lot of fluctuating up and down within these ranges while driving, never noticed this before but then again never paid that much attention to it prior to replacing the parts. Is this normal?
    Not everyday but now and again I notice some light smoke coming from under the hood when sitting at a red light. Popped the hood but cannot locate the source, slight smell of something. I did notice that Coolant resevoir does have some moderate sludge built up in it, could this be the culpret? Would a coolant flush remedy this or could there be a secondary issue?
    Thanks for any input.
  2. #2 Re: Light Smoke coming from engine comp, Infrequent
    Your lim gasket is probably leaking coolant or oil on the motor.
  3. #3 Re: Light Smoke coming from engine comp, Infrequent
    Gotta remember its cold out, exhaust gases steam up and that may be what you are seeing.
    But if you are still running dexcool and the LIM gaskets have never been changed, it maybe a good idea to do them aswell as a coolant exchange.
  1. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  2. S.O.S smoke coming from exhaust...
    By kyleinkman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 07:33 PM
  3. Pours blue smoke, wont idle, check engine light flashes!?
    By 1fastz71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2010, 09:13 PM
  4. Smoke Coming out Of my breaks?
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2009, 05:34 AM
  5. engine light and comp port dont work
    By 1999gpgt in forum General Tech Discussion
    Last Post: 09-29-2009, 06:21 AM
