Thread: Anyone Running 42.5 lb injectors?
Results 1 to 20 of 28
DrSnazzy Anyone Running 42.5 lb... 02-07-2012, 05:15 PM
dsmuts Re: Anyone Running 42.5 lb... 02-07-2012, 05:16 PM
Ricky21 Re: Anyone Running 42.5 lb... 02-07-2012, 05:17 PM
Fivefingerdeathpunch Re: Anyone Running 42.5 lb... 02-07-2012, 05:17 PM
DrSnazzy Re: Anyone Running 42.5 lb... 02-07-2012, 05:36 PM
DrSnazzy Re: Anyone Running 42.5 lb... 02-07-2012, 05:35 PM
Poil336 Re: Anyone Running 42.5 lb... 02-07-2012, 05:48 PM
RegalGS98s Re: Anyone Running 42.5 lb... 02-08-2012, 10:59 AM
DrSnazzy Re: Anyone Running 42.5 lb... 02-09-2012, 11:45 AM
DrSnazzy Re: Anyone Running 42.5 lb... 02-09-2012, 04:55 PM
Fivefingerdeathpunch Re: Anyone Running 42.5 lb... 02-07-2012, 05:49 PM
DrSnazzy Re: Anyone Running 42.5 lb... 02-07-2012, 08:30 PM
dsmuts Re: Anyone Running 42.5 lb... 02-07-2012, 08:35 PM
SlowNA06 Re: Anyone Running 42.5 lb... 02-09-2012, 11:55 AM
DrSnazzy Re: Anyone Running 42.5 lb... 02-09-2012, 04:53 PM
SlowNA06 Re: Anyone Running 42.5 lb... 02-09-2012, 05:12 PM
DrSnazzy Re: Anyone Running 42.5 lb... 02-09-2012, 05:19 PM
txslow6 Re: Anyone Running 42.5 lb... 02-10-2012, 01:15 AM
DrSnazzy Re: Anyone Running 42.5 lb... 02-10-2012, 10:47 AM
SlowNA06 Re: Anyone Running 42.5 lb... 02-10-2012, 11:41 AM
txslow6 Re: Anyone Running 42.5 lb... 02-10-2012, 02:12 PM
SlowNA06 Re: Anyone Running 42.5 lb... 02-10-2012, 02:41 PM
matt5112 Re: Anyone Running 42.5 lb... 02-10-2012, 02:43 PM
darkhorizon Re: Anyone Running 42.5 lb... 02-10-2012, 02:43 PM
DrSnazzy Re: Anyone Running 42.5 lb... 02-11-2012, 01:39 PM
dsmuts Re: Anyone Running 42.5 lb... 02-11-2012, 02:10 PM
DrSnazzy Re: Anyone Running 42.5 lb... 02-12-2012, 11:01 AM
dsmuts Re: Anyone Running 42.5 lb... 02-12-2012, 02:31 PM
  1. #1 Anyone Running 42.5 lb injectors?
    Jan 2012
    N/A
    hey guys , im going to be picking up a set of 42.5 lb injectors from a guy that i bought my gtp from wen. Im kind of new to modding fuel injected motors (yea ima noob) , what kind of changes should i expect as far as performance, mpg, ect after the car is tuned and all? My stock injectors are currently "maxxed out"
    My mods: Smaller Pully For SC
    Ceramic coated headers,
    no cat downpipe,
    3in back to dual flowmaster,
    tuned ,
    Cold air intake.
  2. #2 Re: Anyone Running 42.5 lb injectors?
    how much smaller pulley do you have? Seems like you don't have enough mods to max the injectors out.
  3. #3 Re: Anyone Running 42.5 lb injectors?
    Minnesota
    What size pulley?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  4. #4 Re: Anyone Running 42.5 lb injectors?
    I highly doubt your stock injectors are maxed.
    whats your IDC?????
  5. #5 Re: Anyone Running 42.5 lb injectors?
    Jan 2012
    N/A
    whats your IDC?????
    idc? lmao
  6. #6 Re: Anyone Running 42.5 lb injectors?
    Jan 2012
    N/A
    I have to call the guy and get all the mods he got done, I just got the car like a month ago. Im just going by what he told me as of now, and im probably forgetting some mods . Ill have him send me a list
  7. #7 Re: Anyone Running 42.5 lb injectors?
    Troy OH
    geeze, if your injectors are maxed on those mods, i'd like to see your air/fuel ratio
  8. #8 Re: Anyone Running 42.5 lb injectors?
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by Poil336 View Post
    ^this... Probably why he's only getting 13.8 mpg in the other thread. I've only lost about 2 mpg from a bad O2 sensor when the code shows. But will see once the pulley size and mods are listed. If it doesn't say the pulley size, just measure the diameter. Is he selling you the 42.5lb injectors, or is he giving them to you since you bought the car from him?
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  9. #9 Re: Anyone Running 42.5 lb injectors?
    Jan 2012
    N/A
    Quote Originally Posted by RegalGS98s View Post
    He is giving me those injectors becuase i got the car from him
  10. #10 Re: Anyone Running 42.5 lb injectors?
    Jan 2012
    N/A
    right now its a 3.3
  11. #11 Re: Anyone Running 42.5 lb injectors?
    Whats you injector duty cycle at WOT???
    That will kinda tell you if you're maxing your stock injectors or not. And yes, you need a tuner to figure this out.
    I bet you are only using ~60% because you arent cammed or even intercooled.
  12. #12 Re: Anyone Running 42.5 lb injectors?
    Jan 2012
    N/A
    Oh yea i am also intercooled lol forgot that one sorry
  13. #13 Re: Anyone Running 42.5 lb injectors?
    look on the side of the pulley and see if it says the size
  14. #14 Re: Anyone Running 42.5 lb injectors?
    Pennsylvania
    You don't need those until you drop pulley size below 3.4". 3.2" maybe? Anyway, you'd need at least rockers and an intercooler to go that low. Or a cam. So this is a non-issue. What you need is a good tune.
  15. #15 Re: Anyone Running 42.5 lb injectors?
    Jan 2012
    N/A
    Right now its 3.3, And i also have a 3.2 but obviously not on the car. @SloNA06 my car is intercooled, the guy dropped those injectors off and the other pully today for me, He is going to email me a Detailed list of all the mods done and i will throw that up on here. The car was tuned by zzp i figured that out today. He also said when they went to the no cat system they dropped one o2 sensor, i have to look and see what one was removed. How could i get this code to go away if the o2 sensor is not there?
  16. #16 Re: Anyone Running 42.5 lb injectors?
    Pennsylvania
    From what I've seen, generally, Intercooler and headers = 3.4. Maybe you gots rockers?
  17. #17 Re: Anyone Running 42.5 lb injectors?
    Jan 2012
    N/A
    I dont know man :/
  18. #18 Re: Anyone Running 42.5 lb injectors?
    Texas
    On my previous GTP I didn't max my injectors untill i hit a 3.0 pulley and that was with 1.9's
    Have you scanned your car? We need to know what your IDC is.
    So you know for a fact the injectors are maxed or are you going off what the previous owner told you?
    85 Corvette
    01 TA
    03 Z06
  19. #19 Re: Anyone Running 42.5 lb injectors?
    Jan 2012
    N/A
    Quote Originally Posted by txslow6 View Post
    zzp told him they were maxed out , just going by what he said. I dont even know what IDC is lol
  20. #20 Re: Anyone Running 42.5 lb injectors?
    Pennsylvania
    GenV?
  1. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  2. What do I do with my injectors?
    By FuglyGTP in forum General Tech Discussion
    Last Post: 04-01-2009, 02:12 PM
  3. Which injectors should I be running?
    By FuglyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2009, 02:46 PM
