Thread: Battery 2004 Grand Prix GT
Results 1 to 12 of 12
  1. #1 Re: Battery 2004 Grand Prix GT
    GTX Level Member cerick08GP's Avatar
    A battery is a battery; GPs will run pretty much any 12V automotive battery that will fit. (and in general most batteries fit) Keeping in mind the CCA rating and it having the right posts are key.
    I just replaced my battery a couple months ago using a standard size 34 (top posts) with 690 CCA. Now if I’m correct the size 78s have side posts. I know my 02 GP had side posts, but my 08 GP has top posts. Anyway, just make sure you have the right post configuration is what I’m getting at. And capacity wise I’d aim for about 650-700 CCA, any more would be a waste unless your running huge amps or something.
    Be aware that when I bought my battery they had my replacement battery designated as a fancy gel battery for some reason. Which btw is twice the cost of a regular battery, more over my car didn’t even come stock with a gel battery. Lol
    Also, when you replace the battery it is the perfect time to check the fender well ground. They are in a really bad place and tend to corrode on GPs. The other grounds usually are fine unless they get damaged or something. Just unbolt it with the battery out and clean up the connections with some sand paper or wire brush.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  2. #2 Re: Battery 2004 Grand Prix GT
    Sep 2011
    WV
    Just as an fyi, all batteries aren't created equal. I worked for a manufacturer, I can tell you that for sure. The 34/78 is a top side combination. Its more of a common fit all with more cca's. It stated in the application manual, if replaced with other than thespecial battery could damage the electrical. I was trying to find out if anyone else had seen this issue.
  3. #3 Re: Battery 2004 Grand Prix GT
    Um huh…
    You’re some kind of battery guru and you come here looking for information?
    And you are concerned the “application manual” warning of electrical damage, did it ever run through your mind why the warning is so vague? Heck my manual says I’ll get cancer if I touch my battery, but only if I live in California!?! Hey but who knows maybe the years spent as an electrician I missed a day or two of class on special lead acid batteries. In a round about way I was trying to give you a little practical information that I have picked up over last 11 years maintaining my GPs. But hey just bring it to the dealer; I’m sure they will put a non-damaging battery in. lmao
    2008GP
    2002GP||sold
  4. #4 Re: Battery 2004 Grand Prix GT
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    @cerick08gp , that's not cool bro , I live in california : )
    04 GT1
  5. #5 Re: Battery 2004 Grand Prix GT
    Sep 2011
    WV
    I thought that the throttle body may have need cleaning, I did that earlier in the year, but I didnt check the MAF. I also dont know that the pcv valve has been changed either, but with some reading last night between oil changes on the 3.8 it seems to use up that 1qt. I will have a look at how to clean the MAF as well. I believe that its on top of the throttle body...
  6. #6 Re: Battery 2004 Grand Prix GT
    Sep 2011
    WV
    Quote Originally Posted by cerick08GP View Post
    Um huh…
    What I came here for was maybe a similar expirence, or if someone else maybe has had the same issue. As most of us know about these cars the electrical is very fragile, sorry to make a comment that offended you. I was just trying to get more information and see if anyone else had a similar issue.
  1. 05 Grand Prix GXP Battery
    By Sbacon33 in forum General Tech Discussion
    Last Post: 09-07-2016, 09:25 PM
  2. 2006 grand prix 3.8 gt battery
    By fastbandit in forum General Grand Prix Discussion
    Last Post: 01-15-2012, 07:57 AM
  3. 2004 pontiac grand grand prix gtp
    By jeffreytatro606 in forum Introductions/Noob Questions
    Last Post: 02-03-2011, 06:23 PM
  4. 2000 Grand Prix Gt draining battery
    By Kranium31 in forum General Tech Discussion
    Last Post: 01-22-2010, 07:42 PM
  5. Removing drivers seat in grand prix gtp with no battery
    By mikeh in forum General Tech Discussion
    Last Post: 12-08-2009, 06:33 PM
