A lot of times the ABS light is simply a wheel speed sensor in the hub, which would require hub replacement. It's very easy.
Other times it's wiring and the EBCM module itself.
Suppose it's worth mentioning to check all your fuses, namely the cig lighter fuse, seems it's linked to a few things.
An ABS scan will pinpoint which wheel sensor might be bad.
