Re: PCV wtih an IC (Spade and Sin..get in here)
I have been thinking about this more. I have a couple of ideas.
I would still run a front valve cover on the rear head try one of these PCV valves:
I was thinking I could tap a oil cap and screw this PCV valve into the cap with either an o-ring around the base or some RTV.
http://ecx.images-amazon.com/images/...500_AA300_.jpg
Another option would be to tap the oil cap and put a barbed fitting on it with an inline PCV like this one:
With either way of doing it, the line would then run to the catch can. I will have to tap the EVAP port on the Gen V that is currently blocked off and run a hose from the catch can to that fitting.
