Re: Anyone Running 42.5 lb injectors?
SlowNA06
GenV?
No Gen 3
DrSnazzy
zzp told him they were maxed out , just going by what he said. I dont even know what IDC is lol
Fivefingerdeathpunch
Whats you Injector Duty cycle at WOT???
That will kinda tell you if you're maxing your stock injectors or not. And yes, you need a tuner to figure this out.
I bet you are only using ~60% because you arent cammed or even intercooled.
txslow6
I didn't max my injectors untill i hit a 3.0 pulley Gen 3
So, this would be like a 3.2 on a GenV, right? This cat's got a 3.3 - I wouldn't be surprised if the injectors were going static to quench knock because he doesn't have the proper supporting mods.
No point in guessing till we have scans with WB readings.
you can run a 3.0/3.2 + intercooler = stock everything most the time...
How can i find out what my IDC is
You have to scan it with an aeroforce or if you have an android phone you can use the torque app
dsmuts
I do have the torq pro app, and the adapter. Havent used the app much but i need to know my IDC lol
open the app, go to settings, go to manage extra pids/sensors, go to the menu and add predefined set, select pontiac/gm/opel/vauxhall, then exit the app and uninstall it and reinstall it, then open the app and go to realtime information, go to the menu and add display and select digital, Add knock retard, long term fuel trim, short term fuel trim for bank 1 on both of those, injector pulse width. Then you'll have a lot better info to give us as to what is wrong with your car. Anymore questions just ask.
