Thread: Custom fuel rails
Results 1 to 20 of 22
  1. #1 Custom fuel rails
    Minnesota
    Looking to make some fuel rails for an upcoming IC project. I wasnt to just cut up some stock l67 rails and ad some stainless steel lines. Pretty much like these from ZZP
    ZZPerformance - Modified Fuel Rails #09-01-00534
    Much rather do it myself and save some pennies. So What kind of fittings and line would I need to do this, like sizes and such? I read bills thread about stainless fuel lines but that seemed a little different than what im trying to do lol
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  2. #2 Re: Custom fuel rails
    Omaha, NE
    I would also like to know this information for a series 3 fuel rail if there's any differences.
  3. #3 Re: Custom fuel rails
    Minnesota
    Yea I was gonna ask that too lol Because id rather use the series 3 just because they look better imo
  4. #4 Re: Custom fuel rails
    Omaha, NE
    I think you'd have to convert your whole fuel system to be returnless.
    I guess it wouldn't be too bad if you could find an 04+ in a junkyard.
  5. #5 Re: Custom fuel rails
    Minnesota
    Oh **** thats right
  6. #6 Re: Custom fuel rails
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    The smaller return line is 5/16th's and the bigger line is 3/8th's, you can get the compression AN fittings and make your own lines.
    Or if you can weld... Here's a set I made and did a complete AN conversion
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  7. #7 Re: Custom fuel rails
    Minnesota
    Thats pretty much exaclty what im lookin ti do. Those look great!! But ill have to use l67 rails for the return to work correct? How do the fittings attach to the rails, do they have to be welded?
  8. #8 Re: Custom fuel rails
    Omaha, NE
    They are compression fittings, or you can have welded fittings.
    Most of the fittings I've looked at weren't rated high enough according to Matt5112.
  9. #9 Re: Custom fuel rails
    Minnesota
    Ok I wasnt sure what those were but I found out lol. Hm theres gotta be something out there rated high enough. How much pressure do they have to hold?
  10. #10 Re: Custom fuel rails
    Omaha, NE
    I think he said something like 2-300 and the ones I've found are for "low pressure fuel systems" and rated around 100.
  11. #11 Re: Custom fuel rails
    Feb 2010
    Oklahoma City, OK
    I've pressure tested tested my whole setup underwater up to 140 psi with no leaks... Just saying
  12. #12 Re: Custom fuel rails
    Minnesota
    And you used the compression fittings? Where did you get them from?
  13. #13 Re: Custom fuel rails
    Feb 2010
    Oklahoma City, OK
    Compression fitting... -6 AN to 5/16 and -6 AN to 3/8 x3, so I have 4 compression fittings. Ordered from summit. They seemed to be the cheapest for AN stuff. But it's still pretty expensive.
  14. #14 Re: Custom fuel rails
    Minnesota
    Ok, and you dont have the return because your l32 swapped correct? Any idea what would have to be done different on some l67 ones?
  15. #15 Re: Custom fuel rails
    Feb 2010
    Oklahoma City, OK
    It an l32 in a 98 so I kept the 98 fuel system like everyone does
  16. #16 Re: Custom fuel rails
    He has a return on his setup. See the regulator.
    I was told the Earl/Summit fittings were only good to about 60psi, can't find any specs on them though.
  17. #17 Re: Custom fuel rails
    Feb 2010
    Oklahoma City, OK
    I know a local here did the writeup on the AN line conversion with the compression fittings an he's had his done for more than a few years I think with no issues too. And mines has been fine almost a month now. He had tried to double flare his lines but our line has a seam on the inside which will prevent you from being able to make any good flare setups that won't leak right off the bat. So either compression or weld/braze on ones.
  18. #18 Re: Custom fuel rails
    Minnesota
    Do you have a link to the write up?
  19. #19 Re: Custom fuel rails
    Feb 2010
    Oklahoma City, OK
    It was in the how to section here before they fubar'd it an the search up... Think his handle in here is ironindian or something to that effect.
  20. #20 Re: Custom fuel rails
    Minnesota
    I found it, but it didnt work lol What rails were those from originally?
  1. zzp fuel rails
    By rah575554eg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 12:52 AM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
