Thread: Rocker Question
Results 1 to 10 of 10
  1. #1 Rocker Question
    Sep 2011
    MI
    I emailed ZZP about the best springs to run with the 1.9 modified rockers(with their PCM tune-higher shift points-) and they said stock springs are fine. Can I get away with the stock springs with the higher shift points? The car hardly sees those high rpms though. It would be nice to save a lil and maybe get a scangage er something. But not if it is a huge risk to the motor.
  2. #2 Re: Rocker Question
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    ls6 beehives
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  3. #3 Re: Rocker Question
    Sep 2011
    MI
    But are they needed? This is a DD not a racekar.
  4. #4 Re: Rocker Question
    Texas
    If your shift points are higher than 6K RPM then it's recommended to upgrade the valvesprings.
    85 Corvette
    01 TA
    03 Z06
    Buffalo
    Why do things half ass? If its just a daily driver , why bother changing the rockers out then?
    The springs compliment the rockers. The rockers compliment high rpms.
    Driving around 1-3k rpm you won't notice anything
    Do it right and get springs , retainers , re usable rocker bolts, thread lock and new valve seals. You won't have to touch that part of your motor again.
  6. #6 Re: Rocker Question
    I didn't change my springs but I will when the motor goes into the next car
  7. #7 Re: Rocker Question
    GT Level Member mkyota1's Avatar
    Daytona, florida
    Most get away with stock springs fine. I have heard of a few that had problems. I just installed rockers myself and went with l76 springs. They are cheaper and are more than enough for just rockers. If you get springs make sure you get the right retainers too.
  8. #8 Re: Rocker Question
    You wont make power past 5700 on a stock cam anyways.
    No point in shifting much higher.
  9. #9 Re: Rocker Question
    May 2008
    Winnipeg, MB
    when I did my er rockers, kept getting the advice to do springs as well, did I? nope and don't care
    2007 Pontiac Grand Prix
  10. #10 Re: Rocker Question
    Mileage, age etc all factor into what your springs are likely going to handle. I've seen a lot of guys break a spring on the advice that they don't need to be changed. And yet..there's another whole group that didn't change and didn't have a problem.
    The rub is.. what will your springs take and are you willing to bet your motor on the gamble. Because typically when a spring breaks, the valve drops into teh cylinder and gets hit by the piston. The results aren't often good....
    As an installer, I refuse to install rockers or a cam w/o changing springs. I don't want to put a motor in for a guy because he took a chance on springs.
  1. rocker question
    By lilrocket in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 06:54 AM
  2. Rocker Question
    By Sl33p3rGt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2011, 12:35 AM
  3. Rocker arm question...
    By Death in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2010, 07:50 PM
  4. ?1.9 rocker question?
    By mikesarebetter in forum General Tech Discussion
    Last Post: 11-09-2009, 08:45 PM
  5. rocker question
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 05:57 PM
