Thread: 98 gtp missing...p0300
Results 1 to 9 of 9
  1. #1 98 gtp missing...p0300
    Illinois
    First off ive never done the forum thing before and i know there are a ton of posts about this, but none really have a solution to my problem.
    I have a 98 GTP with 169,xxx. Lastnight it started missing when boosted, so i ran seafoam trough the tank and the middle vac line on top of the sc. I drove it home and let it sit over night.
    Today i started it and it was missing at idle, and backfiring pretty bad. So i changed plugs(ngkTR6's) and wires(napa golds) and that didnt stop the problem so we tested the coil packs and when cyliner 6 and i think 3 were unplugged the backfiring stopped even under a load, so i replaced the top 2 coil packs and am still having the same miss. The only code it is throwing is p0300.
    Ive been reading the common causes of the p0300 code are cat or egr issues. But i have both deleted. Any tips? How would i know if it is a CPS?
  2. #2 Re: 98 gtp missing...p0300
  3. #3 Re: 98 gtp missing...p0300
    Illinois
    Wow. sorry didnt realize there were that many. Im going to try moving an injector in the morning even though i seafoamed. How much do those usually run? and what # do i need if that does turn out to be the problem?
  4. #4 Re: 98 gtp missing...p0300
    Omaha, NE
    Injectors are fairly inexpensive on rockauto.com, less from a junkyard.
    What are your mods? TR6 are a little colder than 104s, so if you're stock, you have the wrong plugs.
    This guy had similar issues to what you're describing http://www.grandprixforums.net/misfi...rpm-57314.html
  5. #5 Re: 98 gtp missing...p0300
    Illinois
    well i the guy i bought the car from bought it modded and he didnt know much. but..3.4", SLP headers/exhaust, 180tstat, has to have pcm because shift points are raised, k&n intake..so TR6's should be fine. also me and a buddy took the oil fill car off the valve cover and looked at the visible rocker and it is sort of a shiny polished red. so possibly 1.9rr's and 90# springs?
  6. #6 Re: 98 gtp missing...p0300
    Omaha, NE
    In that case, before you get injectors, you may want to find out what's in it now as far as injector lb.
  7. #7 Re: 98 gtp missing...p0300
    Illinois
    how would i figure that out?
  8. #8 Re: 98 gtp missing...p0300
    Omaha, NE
    If the previous owner didn't tell you, you'll probably have to pull one to see what it says on it. It should have a serial/ part number on the stem. If you can't find one, take a pic and uplaod it, someone on here should be able to determine what it is.
  9. #9 Re: 98 gtp missing...p0300
    If your injectors are white/yellowish..they are stock.
  1. p0300 missfire
    By falcz420 in forum Engine
    Last Post: 02-11-2012, 02:13 PM
  2. p0300 miss
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2012, 04:30 PM
  3. My P0300 discovery
    By mayoke in forum General Tech Discussion
    Last Post: 09-01-2011, 08:12 AM
  4. P0300 & p0420
    By demetriuslopez in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-07-2010, 07:16 PM
  5. p0300
    By fratzke7 in forum General Tech Discussion
    Last Post: 10-10-2008, 09:19 AM
