Thread: 13.8 MPG! wow....
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 65
DrSnazzy 13.8 MPG! wow.... 02-02-2012, 11:07 AM
ctracer Re: 13.8 MPG! wow.... 02-02-2012, 11:10 AM
DrSnazzy Re: 13.8 MPG! wow.... 02-02-2012, 07:49 PM
OH4CompG Re: 13.8 MPG! wow.... 04-23-2012, 09:41 AM
BillBoost37 Re: 13.8 MPG! wow.... 02-02-2012, 11:11 AM
rodneypierce Re: 13.8 MPG! wow.... 02-02-2012, 11:51 AM
z3r0 My old gtp did 13 in city but... 02-02-2012, 11:32 AM
rodneypierce Re: 13.8 MPG! wow.... 02-02-2012, 12:31 PM
Fivefingerdeathpunch Re: 13.8 MPG! wow.... 02-02-2012, 11:52 AM
MoarkatsINmuhtrailer Re: 13.8 MPG! wow.... 02-02-2012, 11:52 AM
indygrandprix Re: 13.8 MPG! wow.... 02-02-2012, 12:14 PM
matt5112 Re: 13.8 MPG! wow.... 02-02-2012, 12:22 PM
rodneypierce Re: 13.8 MPG! wow.... 02-02-2012, 12:54 PM
rocknnachos Re: 13.8 MPG! wow.... 02-02-2012, 01:21 PM
matt5112 Re: 13.8 MPG! wow.... 02-02-2012, 12:32 PM
darkhorizon Re: 13.8 MPG! wow.... 02-02-2012, 12:36 PM
darkhorizon Re: 13.8 MPG! wow.... 02-02-2012, 12:35 PM
matt5112 Re: 13.8 MPG! wow.... 02-02-2012, 12:39 PM
matt5112 Re: 13.8 MPG! wow.... 02-02-2012, 01:25 PM
DrSnazzy Re: 13.8 MPG! wow.... 02-02-2012, 07:48 PM
redlinepontiac Re: 13.8 MPG! wow.... 02-02-2012, 08:10 PM
Swiggles Re: 13.8 MPG! wow.... 02-02-2012, 08:32 PM
ctracer Re: 13.8 MPG! wow.... 02-02-2012, 10:12 PM
DrSnazzy Re: 13.8 MPG! wow.... 02-03-2012, 10:42 AM
Swiggles Re: 13.8 MPG! wow.... 02-03-2012, 11:05 AM
DrSnazzy Re: 13.8 MPG! wow.... 02-05-2012, 12:22 AM
rodneypierce Re: 13.8 MPG! wow.... 02-05-2012, 03:04 AM
dsmuts Re: 13.8 MPG! wow.... 02-05-2012, 11:14 AM
darkhorizon Re: 13.8 MPG! wow.... 02-06-2012, 10:15 AM
Steel Armadillo Re: 13.8 MPG! wow.... 02-06-2012, 10:22 AM
DrSnazzy But the o2 has never been... 02-06-2012, 12:16 PM
DrSnazzy Re: 13.8 MPG! wow.... 02-07-2012, 08:31 PM
DrSnazzy Re: 13.8 MPG! wow.... 02-09-2012, 04:55 PM
RegalGS98s Re: 13.8 MPG! wow.... 02-09-2012, 05:36 PM
Brett Muszynski Re: 13.8 MPG! wow.... 02-09-2012, 05:44 PM
dsmuts Re: 13.8 MPG! wow.... 02-09-2012, 06:15 PM
Futures Passed Re: 13.8 MPG! wow.... 02-10-2012, 03:20 AM
LowRidinCrew Re: 13.8 MPG! wow.... 02-10-2012, 04:20 AM
Explicit_Spade Re: 13.8 MPG! wow.... 02-10-2012, 04:21 AM
DrSnazzy Re: 13.8 MPG! wow.... 02-11-2012, 04:14 PM
dsmuts Re: 13.8 MPG! wow.... 02-11-2012, 04:20 PM
DrSnazzy Re: 13.8 MPG! wow.... 02-11-2012, 04:27 PM
DrSnazzy Re: 13.8 MPG! wow.... 02-12-2012, 11:02 AM
dsmuts Re: 13.8 MPG! wow.... 02-12-2012, 02:32 PM
DrSnazzy Yea I replaced the o2,... 02-22-2012, 10:46 PM
tylerbinski I ran both for a couple... 02-22-2012, 11:33 PM
darkhorizon Re: 13.8 MPG! wow.... 04-23-2012, 06:44 AM
matt5112 Re: 13.8 MPG! wow.... 04-23-2012, 09:07 AM
darkhorizon Re: 13.8 MPG! wow.... 04-23-2012, 09:12 AM
DrSnazzy Update : Had a super bad... 04-23-2012, 06:42 AM
rynoman03 Re: 13.8 MPG! wow.... 04-23-2012, 06:50 AM
matt5112 Re: 13.8 MPG! wow.... 04-23-2012, 11:32 AM
wa04compg Re: 13.8 MPG! wow.... 04-23-2012, 11:33 PM
DrSnazzy Gas mpg is. Still bad, ... 04-24-2012, 06:15 AM
DrSnazzy I was getting 80mpg for a... 04-24-2012, 06:17 AM
darkhorizon Re: 13.8 MPG! wow.... 04-24-2012, 01:54 PM
wa04compg Re: 13.8 MPG! wow.... 04-24-2012, 06:30 PM
DrSnazzy Dark horizon yes I did for... 04-24-2012, 10:43 PM
DrSnazzy A rear o2 with no cat? ... 04-24-2012, 10:44 PM
wa04compg Re: 13.8 MPG! wow.... 04-24-2012, 11:11 PM
darkhorizon Re: 13.8 MPG! wow.... 04-25-2012, 02:52 PM
wa04compg Re: 13.8 MPG! wow.... 04-25-2012, 08:25 PM
DrSnazzy I'm busy man, I'll make some... 04-26-2012, 01:41 AM
  1. #1 13.8 MPG! wow....
    Jan 2012
    N/A
    How the heck can i only be getting 13.8 mpg in my 2004 gtp? i have Ceramic coated headers, no cat downpipe 3in all the way back, cold air intake, Tuned by last owner. Im thinking i might need new Spark plugs? i really am not peeling out ,or driving it hard a ton.
  2. #2 Re: 13.8 MPG! wow....
    new britain, ct
    what mods are done to the car? check plugs/wires. how many miles? might even need a new fuel filter
    07 Black GXP.
  3. #3 Re: 13.8 MPG! wow....
    Jan 2012
    N/A
    Quote Originally Posted by ctracer View Post
    97k and only real mod is smaller pully for SC
  4. #4 Re: 13.8 MPG! wow....
    Portland Oregon
    Honestly, we have to see the tune that's on the car and what the DTC is to pass judgement. If the car is in otherwise good working order... i.e. headers don't leak, no vacuum leaks, then I would cover maintenance basics. If the plugs and wires are original then get some new delco wires and Autolite 104's and set the gap to .055. If the tune is anything like ZZP's, the power enrich TPS enable could be set really low like 30% across the board. I raised my PE TPS enable back up to stock because it was going in to PE way too often when it was unnecessary.
  5. #5 Re: 13.8 MPG! wow....
    You may want to scan your car and look to see if the O2 is toggling.
  6. #6 Re: 13.8 MPG! wow....
    SE Level Member rodneypierce's Avatar
    Jan 2012
    Cedar rapids, IA
    ^^^ This. Im going to guess its mostly in the tune. There may be something off causing it to dump more fuel then it needs.
    1998 GTP. Stock.
    Bunnell, FL
    My old gtp did 13 in city but 30 highways
    Android Fire
    I'm a Sex Offender
  8. #8 Re: 13.8 MPG! wow....
    Jan 2012
    Cedar rapids, IA
    Matt, not necessarily. Depends on how the car was tuned..... How do you know it isnt tuned Open Loop? Also, how do you know they couldnt figure it out, so just set the SES light to no mil or no report? Anything can happen if someone who has no clue what they are doing starts messing with the PCM.....
    1998 GTP. Stock.
  9. #9 Re: 13.8 MPG! wow....
    any ses lights?
  10. #10 Re: 13.8 MPG! wow....
    Ohio
    do you have cam's tune? lol
  11. #11 Re: 13.8 MPG! wow....
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    its not the plugs causing that bad of mileage. If it was you would have an ses light on and more than likely be able to hear a misfire. Its more than likely the way it was tuned that is causing too much fuel to be used. if you have a scaner check the fuel trim
  12. #12 Re: 13.8 MPG! wow....
    then the LTFT's kick in and correct that.
  13. #13 Re: 13.8 MPG! wow....
    Jan 2012
    Cedar rapids, IA
    Im a big OL fan myself... Prefer SD OL on the LS series stuff, but not sure how well it would work on the 3800 S/C'd stuff.
    1998 GTP. Stock.
  14. #14 Re: 13.8 MPG! wow....
    Nov 2011
    south carolina
    ect or iat? maybe it just needs that much fuel to make that much power?
  15. #15 Re: 13.8 MPG! wow....
    only scott is crazy enough to do that.
  16. #16 Re: 13.8 MPG! wow....
    Feb 2009
    flintnasty MI
    No, tons of people tune in open loop... its just that overlly common outside of clubgp.
    The only people that think its crazy are people that are just long time armchair haters, that never actually do the stuff I do on a daily basis.
  17. #17 Re: 13.8 MPG! wow....
    Feb 2009
    flintnasty MI
    really common to see with leaky headers and closed loop. The o2 sensor picks up fresh air readings, thinks it is driving around death valley and its -30 degrees... then and adds a crap load of fuel when its not needed.
    If not leaky headers then it would have plenty to do with the o2 sensor and or some other common issues. My gtp has never gotten less than 24mpg, and my crappy GTP with plug wires/plugs so bad it wont really even run at wot, and has a broken o2 sensor, gets 19-20.
  18. #18 Re: 13.8 MPG! wow....
    In due time
  19. #19 Re: 13.8 MPG! wow....
    If you're making power then you have no right to complain about mileage.
  20. #20 Re: 13.8 MPG! wow....
    Jan 2012
    N/A
    The last owner had it tuned. I have a check engine light, but it was on when i got the car , owner said the guy didnt clear it after tuning.
138, mpg, wow
