Thread: 1999 GTP shifts odd under hard acceleration?
Results 1 to 10 of 10
  1. #1 1999 GTP shifts odd under hard acceleration?
    Dec 2011
    Grand Prairie, Tx
    I noticed that when I push the accelerator to the floor the car will shift down and then immediately shift back up then back down again as if it can't find a right gear to stay in. what could this be? My car is the Series II Supercharged and just had a transmission installed on it last week
  2. #2 Re: 1999 GTP shifts odd under hard acceleration?
    Ohio
    check the fluid level
  3. #3 Re: 1999 GTP shifts odd under hard acceleration?
    Fluid, condition of ignition system etc. Was this a new or used trans?
  4. #4 Re: 1999 GTP shifts odd under hard acceleration?
    Dec 2011
    Grand Prairie, Tx
    Topped off the fluid today and still does it.
    Throttle position sensor also came back on AGAIN today. After I replaced the sensor the light came back on once more before today and I took off the sensor then put it back on and the issue went away. Now today I started having issues with the damn sensor again and it threw a CEL what a surprise. So tired of dealing with this POS sensor.
  5. #5 Re: 1999 GTP shifts odd under hard acceleration?
    If you change the sensor and the code still keeps coming back it's probably a wiring issue.
  6. #6 Re: 1999 GTP shifts odd under hard acceleration?
    Dec 2011
    Grand Prairie, Tx
    I sprayed carb cleaner in the throttle body and the car is running great again and the CEL immediately turned off
  7. #7 Re: 1999 GTP shifts odd under hard acceleration?
    Quincy, Mass
    that doesnt mean you fix it, it was just tempory. replace the sensor..well check the code to make sure what it is and then go from there. the tps could be the culprit of the shift issue too.
    No more GP 04 Impala SS Indy:
  8. #8 Re: 1999 GTP shifts odd under hard acceleration?
    Dec 2011
    Grand Prairie, Tx
    I've already replaced the sensor like I mentioned above.
  9. #9 Re: 1999 GTP shifts odd under hard acceleration?
    Most likely your shifting issue is going to be related to that sensor. Check the wiring, ScottyDoggs has replaced soem connectors and wiring on his car due to brittle and issues being over the exhaust.
  10. #10 Re: 1999 GTP shifts odd under hard acceleration?
    Apr 2012
    lakewood
    I have a 1999 GT 3.8L I had the same problem and found that there were several issues. TPS plug from the harness had a broken wire inside the plug connector" pen " 2nd Where the throttle body mounts there was a vacume leak between that and the gasket I used some permatex and it cleared up my problem.
  1. Shifts hard when hot.
    By JWillas92 in forum General Tech Discussion
    Last Post: 06-02-2011, 09:50 AM
  2. Hard shifts
    By zildjian102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2011, 10:41 AM
  3. Hard shifts
    By dbextreme in forum General Tech Discussion
    Last Post: 02-13-2010, 09:09 PM
  4. Hard shifts
    By grand prik in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-22-2009, 07:48 AM
  5. Hard Shifts.
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-11-2009, 09:18 PM
