Thread: fuel pump having trouble putting back in...
Results 1 to 11 of 11
  1. #1 fuel pump having trouble putting back in...
    SE Level Member ajc549FF's Avatar
    Lake Zurich, IL
    Just replaced fuel pump putting assembly back in the tank it won't sit flat or flushed to put the snap ring back on help??
    98GTP 3.5in tips, headers, fenderwell intake, 180tstat...3.5pulley?
    1984 Four Winns (Boat) 190 Horizon 19ft open bow...new 350 soon! and Thru Hull exhaust!
    03-07 Duramax Diesel next summer after paramedic is finally over!
  2. #2 Re: fuel pump having trouble putting back in...
    get it level and have another buddy push down on it from the back seat through the small pass through space or get a rubber mallet and carfully tap it down, its kinda tough.
  3. #3 Re: fuel pump having trouble putting back in...
    Lake Zurich, IL
    We get it in there level and then it just pops back out
  4. #4 Re: fuel pump having trouble putting back in...
    yeah, you gotta push hard to make it go down, then hold it there to get the snap ring back on.
    Ohio
    Library the o ring. It's dry
    Sent from my DROIDX using Tapatalk
  6. #6 Re: fuel pump having trouble putting back in...
    Quote Originally Posted by 99pgpgt View Post
    Library huh.
    Ohio
    Lube* lol
    Ohio
    Tapatalking and driving haha
    Ohio
    Get it in?... No pun intended
  10. #10 Re: fuel pump having trouble putting back in...
    Topeka, KS
    Put vasoline all around the o-ring. After i did this i had no problems.
    Ohio
    Agreed with Ryan, I used plumbers grease. Vaseline, oil, dielectric grease, anything like that will work
  1. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  2. So, putting engine back together after cam install
    By NineD9GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 08:25 AM
  3. Putting Factory Stereo Back In 2000 gp
    By MysticStyl3z in forum Audio, Security & Visual Electronics
    Last Post: 09-01-2010, 03:51 PM
  4. Car wont run after putting SC back in
    By funky4stringed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2010, 10:13 PM
  5. Putting front end back togeather
    By Ineverfollow in forum General Tech Discussion
    Last Post: 12-15-2009, 03:46 AM
