Quote Originally Posted by VGPGT View Post
correct - its a '97 GT going into a '97 GTP frame. Where do I start taking the harness off - meaning where is the other end...? I'm aware of the whole harness that I've unhooked from the motor and now hooked up to the motor, but where is the connections that I unhook from the old frame to transfer to this frame?
The harness connections are as follows.
fuse box connection - unbolt a giant hunk of plastic from the rear of the fusebox
3 connectors up by the intake box
ABS connector if present
Other than that, you are home free aside from the alternator wire.
