Thread: 2000 GTP fuel tank.
Results 1 to 5 of 5
  1. #1 2000 GTP fuel tank.
    PCMO
    So I am trying to figure out if my tank is really 17gallons. Filling up the tank from just above empty I usually get around 13gallons in. After filling, the needle moves off of full in less than 20 miles. When it gets low, less than 1/4 of tank the guage fluctuates with accel/decel as well as turns, to a point where it sets of the low level annunciator.
    I would suspect the guage....but twice now while decelerating, for a cloverleaf exit, the car stalled and I had to pull over and restart. Mind you being its a GTP ,I try and take the exit at 40-50mph when I should be at 30-40!! I have replaced the fuel pump so is it possible its not seated right???
    I just have a hard time believing that with 4-5 gallons that should still be in the tank that it would fluctuate that much.
  2. #2 Re: 2000 GTP fuel tank.
    Portland Oregon
    Do you have the steel tank or plastic one? I know 2000 was a fishy year for that. Some cars got plastic ones. If you have the steel tank the fuel does slosh a little and it's a slightly higher capacity than the plastic tanks. The plastic tanks must have better baffling in them because I have driven cars with both tanks and I notice the needle moves less if any with the plastic tank.
  3. #3 Re: 2000 GTP fuel tank.
    PCMO
    Metal Tank
  4. #4 Re: 2000 GTP fuel tank.
    Antioch, IL
    Mine is steel and only moves when I turn the car off. I can turn the car off with "low fuel" Come back the next day and I have 1/8 tank, then drive 5 miles and low fuel. Never moves while driving. The business truck 95 f150 now that sucker MOOOVES. 1/4 to empty when I accelerate.
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: 2000 GTP fuel tank.
    PCMO
    Guy on GPONA forum thinks the internal baffels are broke.
  1. Drop Fuel Tank
    By roundbox52 in forum General Tech Discussion
    Last Post: 07-15-2023, 08:43 PM
  2. draining the fuel tank
    By kavaman in forum Introductions/Noob Questions
    Last Post: 07-24-2011, 07:22 PM
  3. Fuel Tank Sensor going bad
    By GAFF in forum General Tech Discussion
    Last Post: 04-04-2011, 09:40 PM
  4. How many gallon fuel tank
    By kjclawson in forum General Tech Discussion
    Last Post: 11-13-2009, 06:30 PM
  5. fuel tank capicity
    By whiteknuckle in forum General Tech Discussion
    Last Post: 01-19-2009, 07:44 PM
