(Stupid stuff) Any specifics? I want to shift at 5900-6k on the street (5900 into 3rd). Maybe 6300 1-2on the strip (6000 into 3rd). I was also planning on going with a thin mls headgasket to put my compression at 10.01:1. In theory, the overall internal pressure should be offset by the drop in boost the heads should provide.My understanding is that rr's over a mild cam as opposed to a bigger cam will give a stronger power curve without moving the powerband higher in the rpm's. Anyone that can confirm this?
