Thread: Intake: Open Vs CAI
Results 1 to 20 of 100
  1. #1 Re: Intake: Open Vs CAI
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    its not the pipe heating up, open you hood,look at you TB and look underneath it, bam, crossover... heats up the tb.
    and blue im always sitting at lights, so probably why i like my cold air intake better lol.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  2. #2 Re: Intake: Open Vs CAI
    GT Level Member RegalGS98s's Avatar
    NJ
    Non-Contact Infrared Laser Thermometer
    I haven't used it on the car yet, but I did use it on a house heater's exhaust duct. You can see how much hotter the elbows get vs straight pipe and different locations. The temperature on the exhaust about doubled at the the bends. You can use this on our car for checking exhaust and intake temps (not the air in the piping itself). The thing I would use this on the car most for would be checking temps of the crossover pipe and the intake pipe above it. I remember a school testing a Regal's crossover pipes after a run on the track with a thermographic camera. They did stock, wrapped and ceramic coated crossover pipes. You can sorta do the same thing using a tool like this.
    As for intakes, I'll probably make a filter box and then use the intake in the SD Hood on the Grand Prix. For the Regal with it's stock hood, I'll either use the metal tubing CAI I have or make up the PVC pipe intake to get the filter as close to the fender as I can like most have above.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  3. #3 Re: Intake: Open Vs CAI
    Grand Island, Nebraska
    Quote Originally Posted by Grimsin View Post
    Hot air would actually be better while sitting at a light. you dont need any power, so you can use less gas with hot air. hot air=less dense air=less gas. Probably not noticeable though.
  1. Open cone intake clarification
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 08:25 AM
  2. Open Cone Intake
    By demetriuslopez in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2010, 11:11 AM
  3. Open cone intake
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 08-11-2010, 05:01 PM
