Quote Originally Posted by Hippo Machine View Post
When considering how to design an optimal induction system for a particular vehicle, all of the design aspects discussed earlier as well as other characteristics must be given careful consideration. Restricting the design considerations to the aspects discussed above, some basic design conclusions can be listed.
Select a high flow surface impingement style filter element
Use as large a filter element as practical for the application
Position the filter so the least amount of dirt and debris will be entering the filter
Maintenance the filter regularly to maintain optimal performance
Use as large of an intake duct as practical to connect the filter element to the engine
Intake duct's interior surface should be as smooth as possible
Avoid rapid changes in diameters/cross-sectional areas through the induction system
Avoid or limit the bends needed in the induction system
Keep the intake track to the engine as short as possible
The induction system should draw 100% of its air from outside the engine bay or where minimally higher than ambient air temperature regions exist
All induction component surfaces that are exposed to higher temperature components and surfaces should be made of highly thermal reflective materials
All surfaces that come in contact with the intake air should be insulated from all potential heat sources
