Thread: Heater airflow significantly weakens when temp is set to ‘hot’
Results 1 to 15 of 15
  1. #1 Re: Heater airflow significantly weakens when temp is set to ‘hot’
    pretty sure the vac air flops things only move where the air comes from, the actuators control the temp of the air coming into the car. turn the heat to max temp and then remove the actuator on the side thats not right then turn it by hand to see if it turning all the way.
  2. #2 Re: Heater airflow significantly weakens when temp is set to ‘hot’
    Jan 2012
    Ottawa, Canada
    My actuators are electrical and look like those 03 2003 Pontiac Grand Prix Air Flap Actuator - Climate Control - Replacement, Dorman - PartsGeek
    I could see that they move all the way in both directions - there are marks on the housing and on the turning thing (a metal pin). Were you talking about those ones or something else?
    Thank you scottydoggs!
  1. GM 85mm LS6 LQ4 MAF Mass Airflow kit
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2017, 06:08 PM
  2. Mass Airflow Sensor question
    By Dean10e in forum General Tech Discussion
    Last Post: 11-11-2011, 07:31 PM
  3. mass airflow sensor issue,
    By will54768 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2010, 01:19 AM
  4. Backlight issues. Fan controls, Seat Heater, Temp up and down buttons.
    By Minor723 in forum General Tech Discussion
    Last Post: 01-15-2009, 10:39 AM
  5. Backlight issues. Fan controls, Seat Heater, Temp up and down buttons.
    Last Post: 01-14-2009, 10:24 AM
