Thread: window wont roll up!
Results 1 to 10 of 10
  1. #1 window wont roll up!
    GT Level Member natethegreat's Avatar
    Brookings, SD
    Hey all and thanks for looking.im in ned for some urgent help.my driver side window swith stoppedrolling the driver side window up. it will roll down though. i was driving home and i tied rolling the window down but it wasntoing then it snapped and now it wont roll back up. as it is cold here in south dakota i nd it to go back up. any ideas? inthe meen time can i do anything with the connector tohave it go back up? Thanks!!
  2. #2 Re: window wont roll up!
    reach in the crack where it goes down and pull it back up. You'll need a new regulator
  3. #3 Re: window wont roll up!
    Brookings, SD
    Nope dont think thats r. was working this morning and we replaced that about a month ago.
  4. #4 Re: window wont roll up!
    You said it snapped so that's what made me think that the cable snapped on the reg. Pull the door panel and look.
  5. #5 Re: window wont roll up!
    Brookings, SD
    Ohsorry. what i was thinking when i saidsnapped was the plastic switch itslf seemed to snap
  6. #6 Re: window wont roll up!
    Brookings, SD
    any help?
  7. #7 Re: window wont roll up!
    St. Louis
    Just to get it back up, you can pull the door panel and reverse the 2 wires that attached to the window motor. Now it should work in reverse, so when you press the "down" on your door switch the window should go up. Then just disconnect the motor until you can get a new switch.
  8. #8 Re: window wont roll up!
    Brookings, SD
    Thanks! I actually just pulled the connector from the switch and used to jump the brown to black wire and thedark blue to the yellow.
  9. #9 Re: window wont roll up!
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    Mine is doing that but on the passenger side! It will go down but not up with either switch. I took off the door panel and switched the polairty of the wires and it went up fine! Is it the passenger side switch or could it be the main drivers side ? Is there a way to check so I don't have to buy a passenger AND driver's side switch, because electrical parts are non-refundable... I do have a sedan
    Thank you for ANY help!!!!!!
  10. #10 Re: window wont roll up!
    If neither work it's probably your master switch. You could go to a junkyard and swap them out if they let you and see if it works then.
  1. window won't Roll up
    By Austin2000SE in forum General Tech Discussion
    Last Post: 12-02-2011, 11:21 AM
  2. rear window wont roll up or down? help
    By 04gtgp in forum 04+ Specifics
    Last Post: 11-07-2011, 06:12 PM
  3. Windows Wont Roll Up or Down
    By MustangMatt96GT in forum General Tech Discussion
    Last Post: 07-11-2011, 06:16 PM
  4. Passenger window will not roll all the way up
    By kevinpope in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-16-2010, 05:39 PM
  5. Window won't roll up
    By Greenlawnracing in forum General Tech Discussion
    Last Post: 02-22-2008, 11:54 PM
