I see two scenarios. If the subframe is bent. Swap the GTP's subframe over. It's the same frame and veryyyyyy easy.
Or you can pull the axles, undo the mounts (unbolt the master cylinder from the booster adn flop it to the strut tower for more room) then pull the combo together. With wiring intact. Flop it in the GTP and off ya go.
