Thread: Please someone help me out here, starting issue.
Results 1 to 5 of 5
  1. #1 Please someone help me out here, starting issue.
    Jan 2012
    Hobart,IN
    So I have a 1995 Grand Prix SE with a 3.1 and like every 1 out of 3 starts it baaarely starts and when it does it revs up to 3000-4000 rpms then slowly will go back down to idle. Does anyone know what could be causing this?
  2. #2 Re: Please someone help me out here, starting issue.
    Super awesome vacuum leak...possibly.
    Any check engine lights?
    If so, go get the codes read and post them up here.
  3. #3 Re: Please someone help me out here, starting issue.
    Sounds a bit like a maf, vacuum leak etc. Being the super awesome 3.1 I'd look for vacuum leaks first. Like right on top of the TB. Taht stellar vacuum setup should be in teh world of fail.
  4. #4 Re: Please someone help me out here, starting issue.
    Feb 2010
    TN
    vac leak or a weird thing like I had once the positive battery cable melted on fused to the engine block
  5. #5 Re: Please someone help me out here, starting issue.
    Jan 2012
    Hobart,IN
    The check engine light is on randomly and now sometimes a little rubber piece connecting some tube to the pcv valve will blow off when i try to start it and white/light gray smoke would come out. I can just put it back on and it starts fine though. I don't get paid for awhile though so I couldn't get anyone to hook up a computer to get any codes. They said that the smoke is exhaust and it is most likely happening because I have a clogged catalytic converter and it's building up back pressure. Am I going to hurt my engine if I don't replace the cat soon? Because they said I shouldn't worry about replacing it unless I need to pass emissions or my engine starts to lose accelerating power. (they zip tied that rubber piece so it won't come off anymore also) Thanks for all the feedback too
  1. Starting issue
    By GTP Ryan in forum General Tech Discussion
    Last Post: 08-28-2011, 02:55 AM
  2. Odd Starting issue
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 11:04 AM
  3. 04 starting issue
    By peppy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2010, 02:45 AM
  4. Car Starting issue...
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 02:42 PM
  5. Starting issue
    By MuTaLiZeD in forum General Tech Discussion
    Last Post: 07-31-2009, 01:03 AM
