Thread: need some help any ideas?
Results 1 to 11 of 11
  1. #1 need some help any ideas?
    May 2011
    iowa
    Ok so the other day my car threw a P0171 running lean bank 1. Car seemed to be running fine so I deleted it with my aeroforce thinking if it was running lean constantly it would come back right away, well it didnt until today (a couple days later). Ive been meaning to get a tune but I was waiting on a couple more parts so I didnt waste money on 2 tunes. Any ideas what it could be? Been told it could be the o2 sensor upfront, bad injector(s), fuel pump going bad, fuel filter clogged, or my car needs a tune with my mods to get more fuel. Well if you take a look at w body store headers the front o2 sensor only reads the front three cylinders so if it was the pump or filter it would happen to all the cylinders right? Just trying to figure out what it could be. I dont want to destroy my engine.
    1969 chevelle - project car
    2004 Impala SS - Gen V, 3.6 pulley, w-body store headers, SLP power flo catback, 180*, CAI, Northstar throttle body, ported lower intake, intense pcm, egr delete, 104's, zzp strut tower braces, Quad tail light mod, more to come.
  2. #2 Re: need some help any ideas?
    Check for vacuum leaks?
  3. #3 Re: need some help any ideas?
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Could be that ported TB... That will mess with maf readings and might make it run lean. And you already checked good for vac leaks before posting this right?
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  4. #4 Re: need some help any ideas?
    May 2011
    iowa
    no vacuum leaks have an exhaust leak where the egr meets the rear header connection, was waiting to put a couple more parts on to tune it and i was going to delete the egr when i got tuned but i guess ill have to do it sooner than expected. The codes just started happening, ive had that ported throttle body on for almost a year and a half so im pretty sure thats not it.
  5. #5 Re: need some help any ideas?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    vac leak. You have one somewhere
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: need some help any ideas?
    May 2011
    iowa
    wouldnt my boost gauge show me if i had a leak? vacuum pressure shows normal (about between 20-22) and boost is between 7-8lbs.
    Ive got one person telling me its because i need a tune because of my mods and one telling me because of a vacuum leak?
  7. #7 Re: need some help any ideas?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    EGR tube , they crack where they go in manifold.
    Make sure throttle body screen is in and clean.
    Pcv valve o-ring, missing ?
    1997 Red GTP 182000 miles stock
  8. #8 Re: need some help any ideas?
    May 2011
    iowa
    egr tube isnt cracked but the connection to the rear header didnt get a good enough seal because i couldnt get my big ass hands back there to tighten it down all the way, just gonna delete the stupid thing when i get a tune. screen is in and clean just replaced the throttle body gasket two weeks ago so i checked the screen not too long ago. Pcv o ring is fine. if i had a vacuum leak wouldnt my gauge show it? not talking about the stock one in the cluster i have one from autometer
  9. #9 Re: need some help any ideas?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Only way to tell on the egr tube is to remove that end and shine a light in it. They develop a crack around the flared end, very small
    but will trip an p0171
  10. #10 Re: need some help any ideas?
    No.. fix your exhaust leak.
  1. I need some ideas
    By 2000 Pontiac GTP SC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 07:50 PM
  2. tattoo ideas for my cast! post your ideas!
    By putskijr in forum Off Topic Discussion
    Last Post: 07-11-2010, 04:53 PM
  3. ideas
    By erik in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2009, 06:53 PM
  4. Any ideas
    By chad27 in forum General Tech Discussion
    Last Post: 04-13-2009, 06:20 PM
  5. Ideas for '05 GP
    By stoner17971 in forum Visual/Body Modifications
    Last Post: 03-09-2009, 11:11 PM
