Thread: Brake drag please help!
Results 1 to 20 of 28
  1. #1 Brake drag please help!
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    alright my front driver side caliper is dragging when my foots off the break, it pulls the car to one side, hurts my fuel economy and makes a noise. the caliper IS NOT seized its just dragging i havent pulled it off yet but im thinking maybe its the slide? im not sure what to do please help
  2. #2 Re: Brake drag please help!
    Nov 2011
    Walla Walla, WA
    its a floating caliper design. The slide pins could be rusted/gummed up preventing it from doing so. It could also be a stuck piston or a brake line deteriorating. Look for bulges in the brake line feeding it. They deteriorate from the inside and may have a flap come loose that acts as a one way valve for teh brake fluid and it will keep the piston from retracting. If its a stuck piston, replace the caliper. Rebuilding is just replacing the seal and dust cover and its a pain.
  3. #3 Re: Brake drag please help!
    Oct 2011
    Michigan
    ive fixed a floating caliper slide before so i hope its that, ill lool for the brake line when i get the wheel off thanks for that good tip, it doesnt seem like the piston though ive delt with that on other cars and usually it locks the wheel from moving at all.
  4. #4 Re: Brake drag please help!
    Florida
    what i always do is to reinstall the caliper without the rotor on. that way i can move teh caliper by hand back and forth to make sure it moves smooth. if it is gunked up clean it well sand paper if necessary. if you do sand it make sure it is smooth when done and you put grease on it it. it could also be a pad not seated correctly... or the clips holding the pad too can be corroded on or behind the clip keeping the pad from moving when the caliper squeezes. make sure eveything that moves is smooth.
  5. #5 Re: Brake drag please help!
    clean and grease the caliper bolt/pins, and try bleeding the brakes, air in the lines does weird stuff.
  6. #6 Re: Brake drag please help!
    If the slides are good and lubed. Then replace the brake line. I'd automatically do both if you are doing one. You can't typically see a deteriorating brake line when they come apart inside. A bulging is typically a "gonna pop" and not the same as the line coming apart inside and acting like a check valve.
  7. #7 Re: Brake drag please help!
    SWPA
    My brother had a brake line issue on a dirt track car. It bound up so much it made the rotor glow red hot and basically explode. One brake line replacement later, and no more hang up.
  8. #8 Re: Brake drag please help!
    Oct 2011
    Michigan
    you guys keep talking about bad brake lines causing this problem is that really this common? i mean break slides seize up all the time ive never heard of a bad line causing this?
  9. #9 Re: Brake drag please help!
    SWPA
    I never had either until someone else told me to try replacing my brother's line. When the line collapses it keeps pressure on the caliper. If it was just the slide it wouldn't lock the wheel up, it would just slightly drag.
    Mercer, Pa
    Rubber brake line can come apart inside so that it acts like a check valve, on lets pressure into caliper but not out. Not as common as the slider pins but it happens.
  11. #11 Re: Brake drag please help!
    Oct 2011
    Michigan
    my wheel IS NOT locked up, it just slightly drags it made a noise at first now its just warping the rotor
  12. #12 Re: Brake drag please help!
    SWPA
    If you can tell you have to give it more gas than normal, then it is hanging up due to extra pressure on the rotor. I have had slides freeze before, and it really didn't make my wheel drag noticably. It just wore my brakes faster.
  13. #13 Re: Brake drag please help!
    Oct 2011
    Michigan
    yeah the car pulls to that side and the wheel was squeaking when the cars in park i can see the pad still touching the rotor on that side it doesnt do this on the other side and the rotor is glazed all over it
  14. #14 Re: Brake drag please help!
    well..I've done quite a few on older vehicles. My 97 Bonne, sisters 95 Achieva, my 00 Silverado currently has one.
  15. #15 Re: Brake drag please help!
    Oct 2011
    Michigan
    well im gonna try to fix the slide tomorrow and go from there. i feel like at this point though its definitely warped the rotor and worn/cracked the pad
  16. #16 Re: Brake drag please help!
    Oct 2011
    Michigan
    so it was the slide causing the brake drag, lubed up the slide and its better.........but sometimes between going to school and my buddys house to fix the car, my wheel came lose and it snapped a stud so now i have that problem
  17. #17 Re: Brake drag please help!
    Your wheel fell off the car? or just came loose?
  18. #18 Re: Brake drag please help!
    Oct 2011
    Michigan
    it came lose and snapped one of the studs
  19. #19 Re: Brake drag please help!
    You probably should have tightened the lugnuts lol
  20. #20 Re: Brake drag please help!
    Oct 2011
    Michigan
    they were torqued down, i imagine the came lose because of the brake dragging
  1. drag wheels
    By 2001goldGTP in forum Tires & Wheels
    Last Post: 12-04-2011, 10:38 PM
  2. drag times
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2011, 03:58 PM
  3. drag gp's anyone?
    By boosting98 in forum Off Topic Discussion
    Last Post: 07-16-2009, 09:32 AM
