Thread: Brake drag please help!
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Brake drag please help!
    SWPA
    Brake drag would not let the lugs come loose. It has zero effect on the lug nuts. The only way they will come loose, is if they are not properly tightened.
  2. #22 Re: Brake drag please help!
    ^^^X2
  3. #23 Re: Brake drag please help!
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    maybe the vibration caused the lug to come lose? maybe it just broke randomly there 12 years old and rusted, maybe someone losen them in the parking lot i dont know what could have caused it but the were tight and what does X2 mean?
  4. #24 Re: Brake drag please help!
    Nov 2011
    Walla Walla, WA
    Usually if its the slides, the outer pad will be worn. If its a pressure thing like a hose or a caliper, it'll be the inner pad that's worn. Rotting hose more common that you think. Had it happen on a 2000 mini van I was doing a brake job on. All seemed alright till I took it for a test drive and the left front started smoking. Brake line was keeping pressure on the piston and not letting it retract. Remember its just the seal that retracts these pistons so it doesn't take much pressure to hold them out there.
    Brake should have nothing to do with the studs. There's a problem elsewhere for that. perhaps over torqued or something. THat by the way will also cause a rotor to warp. Typical torque on lug nuts is 80 to 100 ft lbs.
  5. #25 Re: Brake drag please help!
    SWPA
    Quote Originally Posted by asite57 View Post
    If there was enough vibration to cause a lug to come loose from full tight the car would be undrivable. Flat out, period, end of story, the only way the lugs came loose was they were not properly tightened. And X2 means he agrees with me.
  6. #26 Re: Brake drag please help!
    Oct 2011
    Michigan
    well the problem was sloved so...
  7. #27 Re: Brake drag please help!
    Did you replace the wheel bearing or are you just running on 4 lugs? 4 lugs should be fine for a while I ran my old car like that the whole time I had it because it had those stupid locking lug nuts on it.
  8. #28 Re: Brake drag please help!
    Oct 2011
    Michigan
    yeah im just running 4 lugs for now when i get some time im gonna just replace the stud
  1. drag wheels
    By 2001goldGTP in forum Tires & Wheels
    Last Post: 12-04-2011, 10:38 PM
  2. drag times
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2011, 03:58 PM
  3. drag gp's anyone?
    By boosting98 in forum Off Topic Discussion
    Last Post: 07-16-2009, 09:32 AM
