Thread: ac compressor kicks on when I turn on the heat
Results 1 to 10 of 10
  1. #1 ac compressor kicks on when I turn on the heat
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    Well, my 04 gp, for the last few months I noticed that when i turn my heat on the ac compressor engages. Im just wondering what the problem might be, Ive seen this once before on one of my friends cars and it was the computer, but I just want to be sure. any help would be greatly appreciated.
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  2. #2 Re: ac compressor kicks on when I turn on the heat
    Pennsylvania
    I'm curious about this myself. About once a month, I'll look down and notice the AC's on for no good reason.
  3. #3 Re: ac compressor kicks on when I turn on the heat
    SE Level Member Ophidia's Avatar
    Nov 2010
    West Fargo, ND
    I've noticed this on occasion as well. I just thought that I'd been accidentally mashing the A/C button instead of the rear defrost, but maybe my car's possessed too.
    2004 GT2 Leather, Sunroof, heated seats, other stuff, but only a little DIC. Also, Kawi Vulcan 2000 http://tinyurl.com/ophidia
  4. #4 Re: ac compressor kicks on when I turn on the heat
    GT Level Member RotyP's Avatar
    Tn
    Do you all have climate control?
    2007 Grand Prix GT - 20% Tint, Red Inlays
  5. #5 Re: ac compressor kicks on when I turn on the heat
    Charles City, IA
    A/c turns on with defrost to pull humidity out of the cabin.
    SMGPFC Two Nipple General
  6. #6 Re: ac compressor kicks on when I turn on the heat
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    X2^^^
  7. #7 Re: ac compressor kicks on when I turn on the heat
    Pennsylvania
    Quote Originally Posted by TheOtherNick View Post
    Mind = blown
  8. #8 Re: ac compressor kicks on when I turn on the heat
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    With def, floor and def the compressor will run unless the temp is below 32 degrees.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  9. #9 Re: ac compressor kicks on when I turn on the heat
    So this is normal? Ok good I was gettin worried for a second. thanks fellas
  10. #10 Re: ac compressor kicks on when I turn on the heat
    SWPA
    Yea its "normal" but its a feature a lot of people dislike. Just be glad we can easily turn the compressor off if the climate control decides to turn it off. On other cars it comes on automatically and there is no way to shut it off from inside. I know guys who disconnect the compressor in the winter time to keep it from happening.
  1. High beams turn on intermittently when using turn signals
    By Boomersooner in forum General Tech Discussion
    Last Post: 01-13-2012, 08:31 PM
  2. just for kicks
    By PrixAngel in forum General Tech Discussion
    Last Post: 12-02-2011, 06:27 AM
  3. ABS kicks in when starting
    By Chunks in forum Brakes/Suspension/Chassis
    Last Post: 05-04-2011, 05:43 PM
  4. New Kicks for the Prix!!
    By thunder71173 in forum Tires & Wheels
    Last Post: 01-22-2011, 02:49 PM
  5. Traction Control Kicks In When Backing Up
    By TronCarter in forum General Tech Discussion
    Last Post: 03-05-2009, 04:53 PM
