Thread: SRS airbag light on
Results 1 to 4 of 4
  1. #1 SRS airbag light on
    Dec 2011
    Rochester new York
    My airbag light has been on ever since I fixed my windows. The Driver window was not working and I ended up doing a few stupid things in order to diagnose the problem. I tried to short-circuits several wires in order to see if the motor is still working or if it is the controller. I even saw smoke but then I later determined that it is the controller/switch that is the problem and I replaced it and everything worked fine. However, since then the airbag light has been on. Can anyone tell exactly what happened electrically and whether it can be fixed or not.
    Thank you for reading
  2. #2 Re: SRS airbag light on
    St. Louis
    Have you checked all the fuses? You probably popped at least one.
  3. #3 Re: SRS airbag light on
    Dec 2011
    Rochester new York
    I checked most fuses including the SIR one but I haven't been able to remove every fuse to check it
  4. #4 Re: SRS airbag light on
    St. Louis
    Check the rest of the fuses (including any under hood ones) and if those check out then time to have the codes scanned at Autozone and see what they point to.
  1. Airbag Light
    By djwags in forum General Tech Discussion
    Last Post: 04-10-2012, 05:50 PM
  2. 97 GTP: Airbag light
    By DanPrixGTP in forum General Tech Discussion
    Last Post: 08-14-2011, 07:37 PM
  3. SRS airbag light on
    By Haulero in forum General Tech Discussion
    Last Post: 12-17-2009, 09:24 PM
  4. Airbag cluster light? ABS/Trac light too?
    By oddwraith in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2009, 09:57 AM
  5. srs airbag light
    Last Post: 02-03-2008, 07:46 PM
