Thread: Glasspack Question
Results 1 to 9 of 9
  1. #1 Glasspack Question
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    lm looking to get a different deeper exhaust tone. Im thinking about a glasspack in place of the resonator, or should i remove both muffler and replace with glasspack? glasspacks are cheap and seem to work. Flowmasters dont seem to work well on these cars. I also have a few other questions while im at it.
    1: What is timing?
    2: What does a Cam do and do you need a lot of supporting mods to have one?
  2. #2 Re: Glasspack Question
    put a glasspack in where you res goes and leave the stock mufflers.
  3. #3 Re: Glasspack Question
    utah
    ^this...and you need a good deal of work for a cam. start with the safetly modding thread
  4. #4 Re: Glasspack Question
    Jun 2011
    yeah ive read that modding thread alot. just wondering more about it and what timing is?
  5. #5 Re: Glasspack Question
    utah
    wiki and google are your friend my....friend
  6. #6 Re: Glasspack Question
    Charles City, IA
    Ignition timing is how many degrees of crank rotation before top dead center the plug will fire.
    Cam timing is how many degrees of crank rotation before top dead center the intake valve opens.
    SMGPFC Two Nipple General
  7. #7 Re: Glasspack Question
    the short of it, timing is when the spark goes off @ the spark plugs, you can advance or retard the timing in deg's.
    in the old days you would used a timing light pointed at the crank and turn the distributor. now a days you need a tuner program to get it done.
    the cam is what opens and closes the valves in the heads, intake and exhaust.
  8. #8 Re: Glasspack Question
    Jun 2011
    What does timing do for a car?
  9. #9 Re: Glasspack Question
    Omaha, NE
    Look for timing in big font about half way down
    Timing belt - Wikipedia, the free encyclopedia
  1. Positioning of Glasspack
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2010, 06:55 PM
  2. Glasspack?
    By NomeCrusher in forum General Tech Discussion
    Last Post: 06-28-2010, 10:51 PM
  3. Help With Glasspack
    By Pontiac Warrior in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2010, 07:28 PM
  4. Adding a glasspack...
    By mcvey in forum General Tech Discussion
    Last Post: 08-07-2009, 01:54 PM
  5. Glasspack Muffler
    By 04GrandPrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 09:41 PM
