Thread: Help With Glasspack
Results 1 to 20 of 21
  1. #1 Help With Glasspack
    SE Level Member Pontiac Warrior's Avatar
    Hudsonville
    Can anyone tell me if a glass pack with a 2.5 inch inlet and outlet and is 30,5 inches long will fit our cars> Any info would be much appreciated thanks!!!!
    Pontiac Warrior
  2. #2 Re: Help With Glasspack
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    with a welder anything will fit. lol get a tape measure and get under your car, is the best way to know for sure.
  3. #3 Re: Help With Glasspack
    GTX Level Member killakross5o4's Avatar
    illinois
    X2^^^^^^^^^^^
    Shortstack Intercooler, 1.9 Rockers, 3.2 pulley,180 drilled T stat,103 plugs, U bend delete with no cat, thrush resinator,3inch pace setter cat back,shift kit,ZZP Chrome tips,,ZZP stage 2 throttle body,homemade 4 inch CAI,DHP tuned PCM,SSAC headers
  4. #4 Re: Help With Glasspack
  5. #5 Re: Help With Glasspack
    illinois
  6. #6 Re: Help With Glasspack
    if you can fit it i dont see why it would be a bad choice.
  7. #7 Re: Help With Glasspack
    Hudsonville
    I guess my biggest question is about the inlet and outlet diameters what size is ideal for flow and such?
    Pontiac Warrior
  8. #8 Re: Help With Glasspack
    2.5" is the biggest you want to go. if you have a stock catback, the inlet/outlet will be 2.25".
  9. #9 Re: Help With Glasspack
    Hudsonville
    So for a stock exhaust i need a 2.25 inlet/outlet to fit the glass pack on the pipe behind the cat and in the pipe before the split?
    Pontiac Warrior
  10. #10 Re: Help With Glasspack
    Charles City, IA
    Yes.
    SMGPFC Two Nipple General
  11. #11 Re: Help With Glasspack
    pittsburgh pa
    i have a 05 gt i wont to put a 12" glasspack after the resonator or should i take out resonator. and put a biger pack . or will it sound beter with the resonator on.
    thanks
  12. #12 Re: Help With Glasspack
    replace the resonator with a glasspack. having both is a waste since you wont be able to run one long one.
  13. #13 Re: Help With Glasspack
    pittsburgh pa
    ok thank you
  14. #14 Re: Help With Glasspack
    illinois
    i just put on the 36 inch jones glass pack from summit...i cant tell a deff from befor i had it on
  15. #15 Re: Help With Glasspack
    pittsburgh pa
    i put my glasspack on today and it was loud as hell. so i kept the pack on but put the mufflers back on for now. how can i make a little quieter . or if i deside to put a new muffler on is what kind should i get. i was thinking flowmaster. or will that be to loud to. help me to pick .
    thanks to all
  16. #16 Re: Help With Glasspack
    Apr 2009
    stockton ca
    magnaflows and borla's are decent and not to loud With my magnas with out tips and with out res it was drony but with res it killed the drone and with tis its a little more agressive then stock but not overly loud
    Never liked flowmasters on the 3.8 cars
  17. #17 Re: Help With Glasspack
    pittsburgh pa
    zzp has Magnaflow resonatorscan i use it as muffler . or can i use the glasspack as a res. and put new mufflers on.
  18. #18 Re: Help With Glasspack
    SE Level Member dbrincefield's Avatar
    Feb 2010
    Dayton
    i have flowmasters on my 03 Monte and i get ALOT of compliments on how it sounds...especially just at idle...alot of people think i'm packin a V8 at idle because its so low!!! but i also think that most prefer magnaflows on the 3.8....go to youtube and type in an exhaust type or something on a grand prix or something and then you'll figure out which you like!!!
  19. #19 Re: Help With Glasspack
    Apr 2009
    stockton ca
    I resently put a res back on my car but a glass pack will work the same way
    res=glasspack
  20. #20 Re: Help With Glasspack
    Feb 2010
    Dayton
    no i do not...i have it straight piped from the cat to the mufflers!!
  1. How loud is the glasspack?
    By Black18Ice in forum General Tech Discussion
    Last Post: 10-05-2009, 12:26 PM
  2. Adding a glasspack...
    By mcvey in forum General Tech Discussion
    Last Post: 08-07-2009, 01:54 PM
  3. Glasspack Muffler
    By 04GrandPrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 09:41 PM
  4. Full glasspack/steelpack exhaust?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 05:38 PM
