Hello again, I have an 04 Grand Prix GT II around 134,000 miles on it that I have been having an issue with the ABS system activating at real low speed. My wife drives the car so at first I almost didn't really think what she was describing was actually happening until it did it for me finally after 14 months of trying to understand what was happening. It's been going on for over a year. I changed the wheel hubs in the front due to bearing noise and play in them about 3 months ago and she said this problem of ABS activating did not go away. I read on line that it seems to be a common problem but could not get a real clear answer as to what is causing it. I figure since it was doing it before and after the front wheel hub change that those are fine. I am planning on changing the rear hubs real soon. Anyone have places I need to look for this problem. Tires are all the same size brakes are all in good working order. I get good bleed pressure from all 4 corners so I think the rubber lines are still ok. Any thoughts?
