What I replaced
Lim gaskets
Both coolant elbows
T stat
Draining the coolant before the lim consisted of vacuuming out the coolant from the t stat housing then removing lower rad hose. Once done I filled up rad to top, ran car with heater cranked then filled again. Problem is that I cracked open the bleeder on the t stat housing and I get nothing but air and no coolant seems to be in upper rad hose. Temp climbed pretty quick. Shut car off about 220 degrees and coolant light now on.
Suggestions?
