Thread: Just finished LIM and tuneup now car overheating pretty quick
Results 1 to 19 of 19
  1. #1 Just finished LIM and tuneup now car overheating pretty quick
    Cambridge, Ontario Canada
    What I replaced
    Lim gaskets
    Both coolant elbows
    T stat
    Draining the coolant before the lim consisted of vacuuming out the coolant from the t stat housing then removing lower rad hose. Once done I filled up rad to top, ran car with heater cranked then filled again. Problem is that I cracked open the bleeder on the t stat housing and I get nothing but air and no coolant seems to be in upper rad hose. Temp climbed pretty quick. Shut car off about 220 degrees and coolant light now on.
    Suggestions?
    2005 E55 - stock
  2. #2 Re: Just finished LIM and tuneup now car overheating pretty quick
    try holding the revs at 1500 to move the coolant around more, and make sure the t stat is in right so it opens, then bleed it.
  3. #3 Re: Just finished LIM and tuneup now car overheating pretty quick
    Held the revs and took a quick run around block... Was overheating then. I guess the t stat could be in upside down lol. Will check.
    2005 E55 - stock
  4. #4 Re: Just finished LIM and tuneup now car overheating pretty quick
    Jan 2009
    Tallahassee, FL
    Yea the tstat has to be open to proper fill the coolant. Let the tstat open up, open the bleeder, then fill till it comes from the bleeder. You'll want to check the lever after a couple of days of driving to make sure all the bubbles are out.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: Just finished LIM and tuneup now car overheating pretty quick
    Nov 2011
    south carolina
    I like to put fill it up as far as i can at the thermostat hole before putting the thermostat in. Fill it till its flush to where the t-stat sits. Then assemble the t-stat. Fill the system with the bleeder open. Close the bleeder. Run it and bleed it.
  6. #6 Re: Just finished LIM and tuneup now car overheating pretty quick
    T stat looks to be in correctly, just opened rad and bleeder (turned heat on high) filled rad. Car got to about 205 and a little bit of coolant came out... still seemed like upper rad hose had very little in it. I kept bleeder open waiting for a constant stream. Do I need to close entire system for coolant to move around? Bloody hell.
    2005 E55 - stock
  7. #7 Re: Just finished LIM and tuneup now car overheating pretty quick
    Temp kept got to 210 & I shut down.
    2005 E55 - stock
  8. #8 Re: Just finished LIM and tuneup now car overheating pretty quick
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    i guess its possible that the t-stat is faulty and is not opening up. Take it out, boil some water and put it in there to see if it is opening. very unlikly its bad, but it is a possibility.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  9. #9 Re: Just finished LIM and tuneup now car overheating pretty quick
    SE Level Member aussie's Avatar
    Dec 2011
    Woodruff, SC
    When its running at temp, feel the upper & lower rad hoses, and the 2 heater hoses.
    They should all be the same temp - give or take a little...
    If they are not, then you have a blockage in the system.
    Does the heat work??
  10. #10 Re: Just finished LIM and tuneup now car overheating pretty quick
    Jul 2011
    Michigan
    you will feel the water go through the upper radiator hose when the t-stat opens....if it opens
  11. #11 Re: Just finished LIM and tuneup now car overheating pretty quick
    Jan 2009
    Tallahassee, FL
    What tstat do you have?
    77 Morris Garage B
  12. #12 Re: Just finished LIM and tuneup now car overheating pretty quick
    195 t stat, i actually put the old one back in the car and the temp is pretty stable but low coolant light is on. Coolant was coming out of the bleeder but not a strong stream or anything. Upper rad hose felt hot but didn't feel like there was a ton of coolant in it. Kinda weird that the temp is fairly stable but the light is on... Heat works good.
    2005 E55 - stock
  13. #13 Re: Just finished LIM and tuneup now car overheating pretty quick
    personally I have the whole system closed. No heat running, rad cap on, then wait till it warms up and bleed it.
  14. #14 Re: Just finished LIM and tuneup now car overheating pretty quick
    Dec 2011
    Woodruff, SC
    I dont know if this is the right way, but this is how I did it...
    Fill radiator - start car - wait until water in radiator drops (it will suck it into engine) - top up radiator - put cap on.
    watch temp guage, when you see it peak at around 235 (on my guage anyways) it will drop back down, showing the Tstat has opened up.
    Open bleeder screw until you get a decent stream. watch guage for Tstat to cycle again, open bleeder... etc
    Keep your eyes on the overflow tank, top it up as necessary.
    I did this 4 or 5 times, then went for a 10 mile drive & bled it again, drove to work the following day, bled it once more when I got home before I shut it off...
  15. #15 Re: Just finished LIM and tuneup now car overheating pretty quick
    Temp got up yesterday but I can't seem to get anymore coolant in yet the light says low coolant.
    2005 E55 - stock
  16. #16 Re: Just finished LIM and tuneup now car overheating pretty quick
    Jul 2011
    Michigan
    you should probably replace the coolant level sensor. And are you sure you dont have a leak somewhere in the system? If it cannot create pressure, then it will get hot. Because when water is pressureized, the boiling point rises. make sure you have no leaks.
  17. #17 Re: Just finished LIM and tuneup now car overheating pretty quick
    Replaced coolant temp sensor and pulled a newb move, haha it was the low fuel light that was on! Anyway, drove car today and no problems except idling - temp was rising. Going to do some further bleeding.
    2005 E55 - stock
  18. #18 Re: Just finished LIM and tuneup now car overheating pretty quick
    HUDSON
    210 is not HOT for modern day cars (F.I. cars). It is normal for the temp to go up sitting still.
    If your uncomfortable with that, just turn the climate control on, this will command the radiator fans
    and keep the coolant temp lower at idle.
  19. #19 Re: Just finished LIM and tuneup now car overheating pretty quick
    PA
    I agree that 210° is not too hot. But it sounds like you had some major air in the system. It may take awhile to get it all worked out.
    Personally, I do as someone else mentioned and fill the radiator and LIM with the t-stat out and the housing off. This makes sure the entire engine is filled with coolant. Then I put the t-stat on and fill the radiator the rest of the way up. I will usually grab and squeeze the rad hoses to get the coolant moving around and let it sit awhile. The coolant takes awhile to get the air out sometimes. Then I start it and make sure to watch the temp and make sure the t-stat opens. I don't think I have ever used a bleeder screw and never had an issue. But air can be a ***** to get out sometimes.
    2001 GSE
  1. make it pretty.
    By wlmrt6 in forum Visual/Body Modifications
    Last Post: 08-19-2010, 05:29 PM
  2. im pretty sure someone does not want me to be happy
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2009, 09:05 PM
  3. Engine Tuneup - Burning off carbon
    By 04CompG in forum General Tech Discussion
    Last Post: 10-30-2008, 08:38 PM
  4. pretty sure it was a GXP
    By gtpinsc in forum Track Sessions and Kills
    Last Post: 10-02-2008, 11:34 AM
  5. (UPDATE 22Aug08) - Pretty sure I'm overheating?
    By Blown97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2008, 03:56 PM
