Thread: What part is this? (Anti-Freeze Leak)
Results 21 to 40 of 57
  1. #21 Re: What part is this? (Anti-Freeze Leak)
    St. Louis
    Quote Originally Posted by Elite6 View Post
    Make sure you replace both elbows while doing job. Also make sure the four insertion points are cleaned. I used steel wool then lubed elbow o rings with motor oil.
    IIRC, the 97's had the 2nd "elbow" molded into the aluminum alt. bracket and is not replaceable separately. Just the o-ring is.
  2. #22 Re: What part is this? (Anti-Freeze Leak)
    SE Level Member Bologna's Avatar
    Oct 2011
    Illinois
    Quote Originally Posted by Sandman View Post
    Its that bolt. You're going to have to take off the both belts to pull off that bracket.
    Alright thanks.
    Quote Originally Posted by FordMan77 View Post
    Ok, i'll check thanks
  3. #23 Re: What part is this? (Anti-Freeze Leak)
    Oct 2011
    Illinois
    Alright I just got back from town with a package of 2 new elbows and I got both belts off and flipped the alternator up but the thing the elbow is attached to is still not free. It looks like the water pump? And also I can only find one elbow?
  4. #24 Re: What part is this? (Anti-Freeze Leak)
    Ohio
    Quote Originally Posted by Bologna View Post
    you can only find one elbow because there is only one PLASTIC elbow. the other is molded aluminum. and be careful not to break it or your gonna be buying a new alt bracket
  5. #25 Re: What part is this? (Anti-Freeze Leak)
    Oct 2011
    Illinois
    Quote Originally Posted by 99pgpgt View Post
    Well where is it at so i wont break it? and I still can't get the plastic elbow off?
  6. #26 Re: What part is this? (Anti-Freeze Leak)
    or timing cover.
    do not pull it on an angle, its okay to wiggle it, but do not pull on an angle.
    Pull in the same direction the front of the motor faces, towards the passenger fender.
  7. #27 Re: What part is this? (Anti-Freeze Leak)
    Oct 2011
    Illinois
    or timing cover.
    Pull the waterpump towards the passanger side?
  8. #28 Re: What part is this? (Anti-Freeze Leak)
    St. Louis
    No need to pull the waterpump. They are referring to the alt. bracket. Did you remove all the bolts that hold this bracket to the engine?
  9. #29 Re: What part is this? (Anti-Freeze Leak)
    Oct 2011
    Illinois
    I removed the alt bracket, which was just roughly a foot long black bar, and the alternator is pulled upwards, but it looks like the plastic elbow goes into the water pump?
  10. #30 Re: What part is this? (Anti-Freeze Leak)
    St. Louis
    That black bar was just a support for the alt. Here are some pics of what your 97 alt bracket should look like. In this example the person did actually snap the coolant elbow that is molded into the bracket. You can see that in pic #1. That also shows the bolt locations for the bracket. IIRC, there is one bolt that is hidden on the left side kinda set back from the rest. You will have to feel for it as you cannot see it.
    In Pic #2 the red circle to the right shows how the coolant flows through the bracket and into the timing cover, hence the built in elbow w/ o-ring.
  11. #31 Re: What part is this? (Anti-Freeze Leak)
    Ohio
    nooooo the alternator bracket is the big hunk of metal that is under the alternator that the two heater hoses go into
  12. #32 Re: What part is this? (Anti-Freeze Leak)
    Oct 2011
    Illinois
    I am having problems finding that hidden bolt. Here is a picture I took an I think I found the bolt but not sure, the second picture shows the bolt.
    It is to the left of the top pulley.
  13. #33 Re: What part is this? (Anti-Freeze Leak)
    St. Louis
    That looks like it. There should also be another bolt on the left side of the bracket over/behind the power steering pulley. That is the one you will have to feel for. I can't remember for sure, but I recall having to take the PS pump loose from the motor and just move it out of the way a but in order to get a clear shot at that bolt, as it will hit the top of the PS pump pulley on the way out and not be fully removed. Might be different on the 97 tho.
  14. #34 Re: What part is this? (Anti-Freeze Leak)
    GTX Level Member Juanmiguel's Avatar
    Mexico
    What is this piece that I have red arrows pointing at? I have a feeling that it is leaking anti-freeze and as you can tell from the second picture, it drips all over my engine. I found a big puddle under my car today (about 1.5 feet wide).
    I have a 1997 Grand Prix GTP 2 Door Coupe
    Most call it coolant elbow, I call it a effin design fail put a plastic piece of sh1t in that part of the eninge talk about "weakest link" dammit! Anyway I replaced mine with copper tubing and hasn't given me any problems yet.
  15. #35 Re: What part is this? (Anti-Freeze Leak)
    on the newer cars the coolant passage gets quite small in the tensioner assembly to make room for a bolt hole.
    Jan 2009
    Tallahassee, FL
    You won't see that bolt from the top. Its kind of underneath those other two hoses if that makes sense. You don't have to pull the PS pump to pull it off as mentioned above. That is a pain in itself to go back on since you do it blind.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  17. #37 Re: What part is this? (Anti-Freeze Leak)
    Oct 2011
    Illinois
    Alright, I got it lose and it wiggles forward and backward but I can't seem to pull it off. I cut the plastic elbow in half because I thought that that might be holding it back but that didn't help much. I tried wedging a flat head screw driver in the crack to give me some more leverage but it didn't work either. Any suggestions?
  18. #38 Re: What part is this? (Anti-Freeze Leak)
    St. Louis
    Maybe try turning it back and forth (clockwise and counter-clockwise) some as you pull straight out towards the strut tower. The large o-ring may be sticking in the cover. Whatever you do don't pull on it at an angle.
  19. #39 Re: What part is this? (Anti-Freeze Leak)
    Oct 2011
    Illinois
    I've tried that too but still nothing. Should I pull as hard as I can or would that be too much force for it?
  20. #40 Re: What part is this? (Anti-Freeze Leak)
    St. Louis
    Without being there it's kinda hard to tell, but yes, it may need a good strong pull. This may also be a good time to teach you about making sure there is nothing in the way for when it does pop loose that you will smash/cut your hands on. Always check your surroundings or you will be throwing the bracket once you remove it
  1. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 3
    By dsh1106 in forum How To Write-Ups/Tech Tips
    Last Post: 02-09-2013, 06:55 PM
  2. Replies: 2
    Last Post: 08-04-2011, 08:58 AM
  3. Anti Freeze Leak
    By JB381 in forum General Tech Discussion
    Last Post: 02-26-2010, 09:00 PM
  4. Oil "Leak"/Anti-freeze dump
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 08:06 PM
  5. Headlight Anti-Shake Kit - Install 2004 Model Only - Part 2
    Last Post: 04-17-2009, 02:20 PM
