Thread: Anyone got a write up one Power Steering pressure hose
Results 1 to 5 of 5
  1. #1 Anyone got a write up one Power Steering pressure hose
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Cant seem to find one or any real info on it. Got any help guys
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Anyone got a write up one Power Steering pressure hose
    You'll probably have to lower the back of the subframe a little bit to get in there very good but a 18mm line wrench should be all you need.
  3. #3 Re: Anyone got a write up one Power Steering pressure hose
    St. Louis
    I can't remember which one is the pressure line, but when I did my rack I was able to reach down from the top of the motor and get the top line loose, and then once it was out of the way I went up from the bottom and got the other one. Lowering the subframe would have helped but I got it w/o doing that. If I did it over, I would lower the frame, lol...
  4. #4 Re: Anyone got a write up one Power Steering pressure hose
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    yea, the pressure line feeds into the bottom of the PS pump. You MAY be able to get to the rack side of the line without lowering the subframe, but I dunno, it's pretty tight!
    For all your 3800 needs:
  5. #5 Re: Anyone got a write up one Power Steering pressure hose
    St. Louis
    The pump side can be reached by removing the pass. tire and going through the wheelwell, I do remember that part for sure.
  1. Power steering high pressure line 04+
    By Javi in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2011, 09:37 AM
  2. 2002 Grand Prix power steering hose replacement.
    By ktom6 in forum General Tech Discussion
    Last Post: 06-29-2011, 10:31 PM
  3. How to replace Power Steering Hose
    By webxfx in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-09-2010, 07:56 AM
  4. How to remove Power Steering pressure line?
    By cmdragon2001 in forum General Tech Discussion
    Last Post: 09-24-2010, 05:03 PM
  5. power steering air pressure.
    By Teardrop in forum General Tech Discussion
    Last Post: 09-18-2010, 08:44 PM
