Thread: Heating Problem
Results 1 to 2 of 2
  1. #1 Heating Problem
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    Now that winter is upon us in the midwest, I have had to use my heat. But i have ran into two problems. First problem is the fan only works on speeds 3,4, and 5. The second problem is I only have heat on the driver side, cold air just blows on the passenger side.
    Any help and solution to the problem is greatly appreciated
    If it helps I drove a 01 gtp
  2. #2 Re: Heating Problem
    St. Louis
    For the fan speed sounds like a bad blower motor resistor. As far as the blowing cold air on one side, sounds like a blend motor issue. Do a quick search for this issue here as I've seen it pop up quite a bit. I don't personally know much on it other than I'm glad I have a 00 w/o the dual climate control, lol..
  1. Car still heating up
    By dboyw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2011, 06:54 PM
  2. heating problem with a 06 prix
    By stuey in forum General Tech Discussion
    Last Post: 12-08-2010, 06:10 PM
  3. GTP over heating
    By Brandon Busenitz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2010, 11:06 PM
  4. Over heating?
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-27-2008, 09:25 PM
