Thread: what should i check on when the car dies out while driving?
Results 1 to 11 of 11
  1. #1 what should i check on when the car dies out while driving?
    GT Level Member spider4's Avatar
    Nov 2011
    portsmouth,virginia
    So driving down the road at a slow speed i press the brakes and the car just cuts off.The little battery light comes on and steering locks up.This is the second time in the last 30 days that it has done this.It has cut back on both times when i turn the key and it drives along as if nothing happened.Im not a mechanic but my feeling when its done it both times is that not enough gas is pumping through.I have to say ive looked at the fuel filter when i got this car and it and the wires immediately around it have a good deal of rust.The car runs fairly strong and steady until it does this,but again when it does cutout can restart and no problems?My other thought,again not having alot of knowledge is would the sparkplugs and the coil have something to do with it? If a coil is bad or rusted it wouldnt give the best connection.what other things would cause this?There is no overheating and for the most part the idle is steady.
  2. #2 Re: what should i check on when the car dies out while driving?
    St. Louis
    Try cleaning the MAF.
  3. #3 Re: what should i check on when the car dies out while driving?
    Nov 2011
    portsmouth,virginia
    Ok fordman.And heres the 'Im not a mechanic question".What all is the MAF.I know this means mass air flow,but what makes up this part.Is it the box with the filter and hosing running up to the engine?
  4. #4 Re: what should i check on when the car dies out while driving?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    its on your throttle body
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  5. #5 Re: what should i check on when the car dies out while driving?
    St. Louis
    To expand on that answer (which is correct) the MAF is a black sqaure sensor that sits in the TB and has 4 safety torx screws holding it in. They have little pins in the middle of them that require a special torx bit to remove.
    While you are out getting the proper torx bit pick up some CRC MAF cleaner (is specific for cleaning MAF sensors- do NOT use carb or brake cleaner). Should be about $8 for a can. Remove the MAF and spray the small wires that you can see by looking into the sensor. Don't touch the wires as they are very fragile. Let it dry out then reinstall and take it for a drive and see what you get.
  6. #6 Re: what should i check on when the car dies out while driving?
    GT Level Member Brian99SE's Avatar
    Dec 2011
    Cadiz, Ky
    Wait... The Steering wheel Locks up? Define? Just the no power steering kinda lock or more like a ignition lock?
    99 Grand Prix SE-Blue CAI, 3.03 GR Transmission, U Bend Delete.
    time to call the exterminator
  7. #7 Re: what should i check on when the car dies out while driving?
    Nov 2011
    portsmouth,virginia
    brian.power steering kinda lock when your power stops.I didnt really mean to make that even an issue.Ive had plenty of cars do that when they cutout.Anyway i will have to look into the MAF clean thing.Since i got this car in november ive discovered several issues i want to tackle.Money is the issue.My hopes is it will get me to march and ill have at least $1000 to put into it.
  8. #8 Re: what should i check on when the car dies out while driving?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Quote Originally Posted by FordMan77 View Post
    The MAF on a SC only has 2 screws.
    1997 Red GTP 182000 miles stock
  9. #9 Re: what should i check on when the car dies out while driving?
    Nov 2011
    portsmouth,virginia
    Not that it matters i have the GT,not SC.
  10. #10 Re: what should i check on when the car dies out while driving?
    Quote Originally Posted by GTP in RTP View Post
    my 98 has 4 holding the maf on. maybe the 04+ only have 2 screws?
    i took a cut off wheel to the the tops of the bolts and cut a line across the screws, and then used a flat head screwdriver to remove them. a hack saw will work too or a dremel with a cutting wheel on it will work too.
  11. #11 Re: what should i check on when the car dies out while driving?
    Because it dies when you apply the brake at near idling speeds, it may be vacuum related. I would double check all vacuum hoses for cracks, breakage etc. The reasoning behind this is your brake booster works via vacuum. That elbow where the hose goes into the booster is actually a check valve.
  1. Hello from Grande Prairie, Alberta...GTP dies while driving,MAF & EVAP codes
    By rodsridess in forum Introductions/Noob Questions
    Last Post: 04-18-2010, 08:45 AM
  2. 2000 dies while driving?
    By turbostang7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-04-2010, 11:20 AM
  3. Car Dies
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 04:14 PM
  4. Driving on express way at 65 mph, engine dies! What the???
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2009, 03:10 PM
  5. 97 supercharged grand prix v6 dies after about 15 minutes of driving
    By emericadrew in forum General Tech Discussion
    Last Post: 09-06-2009, 03:42 PM
