Thread: What is the Yellow button??
Results 1 to 18 of 18
  1. #1 What is the Yellow button??
    SE Level Member aussie's Avatar
    Dec 2011
    Woodruff, SC
    Below the drivers side dash, next to the OBDII port I have a small round yellow button, anybody know what it is???
    It looks factory, but I dont know...
  2. #2 Re: What is the Yellow button??
    Out West
    Probably trunk
    Whine with your Cheese?
  3. #3 Re: What is the Yellow button??
    Dec 2011
    Woodruff, SC
    Nope - trunk button is in the glovebox...
  4. #4 Re: What is the Yellow button??
    Out West
    Nitrous!
  5. #5 Re: What is the Yellow button??
    Dec 2011
    Woodruff, SC
    Lol - Unlikely - But good guess :-)
  6. #6 Re: What is the Yellow button??
    Portland Oregon
    Does it do anything when you....... push it? lol In all honesty, probably a previous owner that had either a kill switch or an aftermarket alarm installed and that was the valet button or something.
  7. #7 Re: What is the Yellow button??
    Donating Users
    Aug 2011
    Lowell, IN
    DO NOT PUSH IT!
    It is the ejection seat.
    '99 GTP coupe, bone stock because I have enough troubles already.
  8. #8 Re: What is the Yellow button??
    Kinda interesting HIXC has one there too. I figured he or previous owner added it as it looks like a transplanted trunk button.
  9. #9 Re: What is the Yellow button??
    Milwaukee
    it has something to do with tire presure sensors or something. my 2000 gtp doenst have it, but my friends 97 gt does
  10. #10 Re: What is the Yellow button??
    SE Level Member timreams's Avatar
    Aug 2011
    Southwest of Pittsburgh
    i had (what i thought was) a problem with the TPMS on my 04 when i bought it and did a lot of googling and you are correct. that yellow button is to reset the TPMS. it was only after spending A LOT of time online that i figured out that in the newer cars witha DIC that mine did not have the yellow reset button (in fact that is how is found this site).
    so you are correct it is a TPMS reset.
  11. #11 Re: What is the Yellow button??
    Dec 2011
    Woodruff, SC
    Cool - thanks guys..
    My TPMS light stays on all the time, so I figured is wasnt working..
  12. #12 Re: What is the Yellow button??
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    i got one too.. hell it seem harmless i pressed it and waited.. nothing happened.. i was kinda disappointed lol
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  13. #13 Re: What is the Yellow button??
    Dec 2011
    Woodruff, SC
    Would be nice if I could push it and all the vacuum leaks & MAF problems would go away..
    And fill the tank too....
  14. #14 Re: What is the Yellow button??
    Its for the tire pressure monitor, let some air out of one of your tires the low pressure light will kick on that button is to shut off the light.
  15. #15 Re: What is the Yellow button??
    Bunnell, FL
    it's 97 only
    they did away w/ it in 98 since the "new" tcs didnt play well with that system
    oh well i have it disabled in my car, but thanks to gm no traction control
    I'm a Sex Offender
  16. #16 Re: What is the Yellow button??
    Jan 2012
    northen colorado
    if you get down there and look up at the button it should say calibrate tire pressure on the trim ring around the button
  17. #17 Re: What is the Yellow button??
    GTP Level Member simbah's Avatar
    Lala land
    If you push it your car turns into a Pontiac
    OOps you must have already pushed it
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  18. #18 Re: What is the Yellow button??
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    when you have a low tire the light comes on then you fill up your tire to the right level and the light is still on, you have to press and hold the botton to trun the light off but make sure all your tires are at the right level first
  1. 04+ 3 button to 5 button upgrade
    By Mad Monkey in forum How To Write-Ups/Tech Tips
    Last Post: 08-30-2016, 05:00 PM
  2. Yellow fogs
    By djrepoman in forum Visual/Body Modifications
    Last Post: 12-28-2010, 11:25 PM
  3. yellow fluid
    By backinblackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2010, 01:40 PM
  4. Yellow Dog Linux for PS3???
    By shawnz90 in forum Off Topic Discussion
    Last Post: 12-18-2009, 02:09 AM
