Thread: Summit Racing headers & best sound question
Results 1 to 20 of 29
Threaded View
  1. #10 Re: Summit Racing headers & best sound question
    Keller,TX
    Whatever you say... I guess if you get longtubes and they don't fit, you can't say I didn't tell you so.
    I read wrong anyway, those are truck headers "Headers, Full-Length, Steel, Painted, Chevy, GMC, SUV, Pickup, Small Block, Pair" Summit Racing SUM-G9006 - Summit RacingĀ® Headers - Overview - SummitRacing.com
    That came up when I searched for 00 GP headers.
    Long block and short block as nothing to do with the way an engine sits in an engine bay. Please see below.
    ***Edit: Below was taken from a 10 second Google search***
    Long Block Engines
    If an engine was pulled directly out of a car with all the attachments, including wiring, it would be referred to as a long block. If purchasing a long block, it will be substantially more expensive than a short block.
    Short Block Engine
    A short block engine is also referred to as the engine core. This sub-assembly includes the cylinder block, pulley hub, front cover and engine plates. Essentially it is a stripped engine, typically what a mechanic would service when performing an overhaul.
  1. Summit racing has a clearance on front cross drilled/slotted rotors
    By Wotgtp in forum Brakes/Suspension/Chassis
    Last Post: 11-22-2011, 08:17 AM
  2. Summit racing have any special coopin's out now?
    By Wotgtp in forum Off Topic Discussion
    Last Post: 06-08-2011, 10:36 PM
  3. new back brakes. Hows the summit racing rotors?
    By mxthunder in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2009, 11:15 PM
  4. l67 SUMMIT SELLS ARE PISTONS!
    By GTPJOE90 in forum Shops and Community Heroes
    Last Post: 08-16-2009, 03:06 AM
  5. drag racing question?
    By 2000GTP in forum Off Topic Discussion
    Last Post: 07-10-2009, 04:06 AM
