Re: Does 1997 GTP SC have PCV o-rings ?
I will pull it and check, I don't recall seeing the o-ring in the hole, dealer item or find one at auto parts store or Harbor Freight ?
Does anyone recall size ?
I pull out my Harbor Freight o-ring kit when I need one. :th_winking:
BillBoost37
DH is talking supercharged. But unless you lean over and look into the hole, you'll never see the strainer.
You can barely see it from below as well. See the thing in the hole
http://i20.photobucket.com/albums/b2...er/yeah005.jpg
that's the strainer. Anyhow one o-ring on the bottom piece of the pcv and seal the top cover.
ok, so only one o-ring, i notice the NA's have a black one on top of the PCV.
Also you say seal the top cover, there is a gasket there,is that enough? or maybe a little RTV ?
Thanks
So can one little missing o-ring in a PCV actually cause a rough idle and throw a p0171 , I guess I will find out soon.
GTP in RTP
Would I have told you about it if it were an optional part? :th_king-evil:
Not having the ring can put let pressures go back and forth w/o anything stopping them. Hence the job of the positive crankcase ventilation valve.
Since you might not believe me, but you'd believe someone that put something unchecked on the internet.. here ya go
Crankcase ventilation system - Wikipedia, the free encyclopedia
GTP in RTP
It can. I would expect it.
rocknnachos
I believe you guys, not questioning your knowledge, I am just trying to learn things,
Will try this weekend when I can get some daylight, thanks for all the help.
